#11
"Richard Thomas" wrote in message ... Hi Steven, Howzit goin'? I wouldn't like to be on your aeroplane if you're not going to hold anywhere if you're 30 minutes early arriving at your destination with lost comms etc... :-) Why not? If you are in IMC and loose communication then one should start any available instrument approach into the destination airport at the ETA within the filed flight plan (ETD + Time Enroute). If you're early and its solid IMC you hold. Simple as that. The reason for this is Air Traffic is expecting you to arrive at the airport at that ETA so they will have cleared the airspace in its entirity, expecting you to start any published instrument approach into the airport. This is particularly relevant if your transponder has also failed... how are Air Traffic supposed to know where you are? I see a couple of problems with that. First, it's unlikely ATC has your ETA. They'd only have it if you were cleared as filed and there had been no route amendments since you departed. That's rarely the case. Second, what bizarre failure causes me to lose both of my completely independent transceivers, and my transponder, but leaves me fully confident of the continued flawless operation of my other avionics? If you arrive, lets say 30 minutes ahead of schedule, you have no comms and as its your very unlucky day your transponder has decided to go unservicable. ATC have no idea where you are but as they will be following the FARs they'll be clearing the area for your planned ETA. If you are now 30 minutes ahead of schedule (great tailwind) then they may still be clearing the approaches... if you then start an ILS approach in solid IMC, there could be a possibility of ploughing straight into another aircraft that they are getting onto the ground in anticipation of your arrival 30 minutes later... So if I arrive 30 minutes early I should hold while arrival and departure traffic fly through my holding pattern? I'm familiar with what the FARs and the AIM say. What I say comes from 20 years experience as an air traffic controller, Center, TRACON, and tower. You can believe what I tell you, or you can believe your fantasies, I don't care which. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Screw hold repair in fabric? | Brian Huffaker | Home Built | 11 | May 29th 04 03:07 AM |
| Need Hold Harmless Waver for Ultralight or Experimental Sale | Larry Smith | Home Built | 9 | August 19th 03 03:47 AM |
| Need a Waiver/ Hold Harmless Agreement for UL / Experimental Sale | Richard_Tonry | Home Built | 2 | August 17th 03 01:58 PM |
