I have the same carb and a delrin needle and took the carb apart
recently to check for trash because a friend told me he found a dirt-dauber in his float chamber. I was running a little lean. I replaced the big gasket after finding nothing inside. This carb has always worked well and not dripped even though the fuel run through it may vary. I have rebuilt several of these very simple carburetors and think a lot of them, but they won't give you the oomph or diversity of a Marvel Schebler. The mix control is working on mine but it doesn't kick in until you get to something like 1500 rpm, making it almost impossible to kill the engine by starving the mixture, although it CAN be done by completely leaning and firewalling the throttle. The last Stromberg NAS3A1 I rebuilt we tested on the bench and the steel needle would not seat completely. It dripped a little, so the A&P/IA who signed it off whacked the needle against the seat with a hammer. Which stopped the leak. Don't ask me how hard to hit it. It must be done gingerly, deftly, prayerfully. BTW, the ultimate authority on Strombergs is Neal Wright (Cougar) of Sacramento. |
| Thread Tools | |
| Display Modes | |
| Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 02:48 AM |
| Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 06:29 AM |
| Use of Carb Heat | John Kirksey | Piloting | 4 | November 30th 04 08:26 PM |
| Bendix drives. | JDupre5762 | Home Built | 6 | May 16th 04 02:23 PM |
| Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 04:32 PM |
