"Montblack" wrote: ("Thomas O'Grady" wrote) [snip] I have a pod on my Cessna 206. It comes to a point on the front, but the sides and bottom are all flat sheets and the corners have very little radius, maybe 1 inch. It wraps up the side of the fuselage about 4 inches, so the bottom is actually flatter than the original. It is less than 8 inches behind the exhaust. What's the approx size of your pod L-W-D? (...forget the ends if that's an easier est. g) How do you access it? What did it cost in performance numbers before-and-after? Noticeable? Oh, what's the back of your pod look like? Thanks. Montblack Useable about 40 inches W x 70 inches L x 9 inches D, overall 96 inches L 10 inches H x 27 inches W door on side. Book says 5 to 8 mph and 50 fpm climb Width tapers from 40 inches at 60 inches back to 30 inches at 84 inches to 20 at end. Bottom is flat and curves up to meet the fuselage. Book says "designed to accommodate three 'two-suiters' plus misc" |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Would the AH-6J (Little Bird make a good, low cost, helicopter for force protection? | John Hairell | Military Aviation | 1 | May 17th 04 04:21 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
