Small 4 stroke engine?
Old June 9th 05, 06:38 PM
rpellicciotti
This is a close match, Richard:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
  #32
Old June 9th 05, 09:54 PM
Stan Premo
Try http://www.wankel-rotary.com/
"kumaros" wrote in message
news:1118157997.450933@athnrd02...
Richard Riley wrote:
I'm looking for an engine that may not exist. If anyone has a notion
of what it might be, I'd be grateful.
It's for a 103 legal ultralight.
60 lbs or so all up, including re-drive and cooling
35-40 hp.
4 stroke.
More reliable than a 2 stroke Rotax
Any ideas?
The Mid-West GAE 50 R for Ultra (Micro)Lights, Homebuilt or Kit-Planes:
72 lbs / 50HP
http://www.tiho-hannover.de/bmt/bmt/...kel/ggkart.htm
Kumaros
It's all Greek to me
  #33
Old June 10th 05, 12:49 AM
The don't appear to have any sales representatives.
Hard to get a price that way.
FF
  #34
Old June 10th 05, 04:57 PM
Stan Premo
There was an email address either on their site or out of Ultralight Flying
Magazine that responded in a couple of days with a
price list and some mounting info. I'm not sure this will format in the
spreadsheet form I received it but I'll try to paste it in...here goes...
Engine Power Description Retail US$
LCR 407 SGti 37.5 HP @ 6,000 rpm single rotor aircraft and marine
engines $5,691.95
LCR 407 SG/w 41 HP @ 6,900 rpm single rotor Kart engines $5,174.50
LCR 407 SG/k 41 HP @ 6,900 rpm single rotor Kart and industrial
engines $4,822.50
LCR 814 SGti 75 HP @ 6,000 rpm Twin rotor aircraft and marine engines
$7,968.95
LCR Twinpack 150 HP @ 6,000 rpm Four rotor aircraft and marine engines
$16,735.00
*LCR - Liquid Cooled Engine, Charge Cooled Rotor
SG = Single rotor, Gasoline
*ti =Tric-Ignition system
*w version includes carburetor, clutch, electric starter & generator
*k version includes carburetor, electric starter or shaft
Accessories
For Engine Part number Description Retail US$
LCR 407 153 110 Exhaust pipe kit $442.75
LCR 814 152 610 Exhaust pipe kit $638.25
LCR 407 152 121 Stainless steel muffler $977.50
LCR 814 153 621 Stainless steel muffler $1,425.00
LCR 407 156 121 Radiator - steel $615.00
LCR 814 156 122 Radiator - steel $615.00
LCR 407 156 123 Radiator - aluminum $845.00
LCR 814 156 124 Radiator - aluminum $845.00
LCR 407 & 814 154 100 *HDT Reduction Drive $910.00
LCR 407 153 110 Exhaust Pipe & Assembly Kit $442.75
LCR 814 152 610 Exhaust Pipe & Assembly Kit $638.25
LCR 407 & 814 154 100 Reduction Drive (3:1 or 2:1) $910.00
LCR 407 & 814 155 541 spark plug
LCR 407 & 814 151 041 air filter (tapered)
LCR 407 & 814 155 333 V-belt 10x530 Z21
LCR 407 & 814 155 310 generator c/w regulator
LCR 407 & 814 155 611 electric starter
LCR 407 Kart 153 182 engine cover
LCR 407 Kart 155 522 ignition coil PVL
LCR 407 Kart 155 531 high tension lead
LCR 407 & 814 155 203 Electronic Tachometer
LCR 407 & 814 155 202 Coolant Temperature Gauge
LCR 407 & 814 155 205 Ambient Temperature Gauge
LCR 407 & 814 155 204 Voltmeter
LCR 407 & 814 155 206 Hour-meter
Terms - 10% with purchase order
- 40% 30 days prior to delivery date
- balance payable on delivery
- Dealer & OEM terms as arranged
- FOB Oshawa, Ontario, Canada
Stan Premo wrote:
Try
FF
  #35
Old July 1st 05, 09:16 AM
mick
Not sure if this was mentioned earlier in this rather old thread, but
these guys have a pretty interesting solution.
http://www.ecofly.de/english.htm
  #36
Old July 2nd 05, 07:25 PM
mick
karel wrote:
on the negative side: this thing wants unleaded fuel only
so no 100LL, might be problematic even in Europe
and I think worse across the pond
You can always run 100LL and use a lead
scavanger, like http://www.decalinchemicals.com/
for myself I should be more interested
to see a similar aircraft conversion
of the smart diesel engine
Last time I spoke to them, early 2003, they were
working on it. Not sure if they still are, or
what the status is.
Mickey
Thunderstorm - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 11:05 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
