"RST Engineering" wrote in message ... I don't understand what advantage this has over simply deflating the strut, removing the schrader fitting, filling it to the brim with 5606 That will work just fine if you can get the fluid to it, way back there on the firewall behind the mags and alternator and all those wires, without making a mess. , replacing the schrader, and pumping it with a gas (air or nitrogen). You can argue for nitrogen if you want, but the sloshing of the 5606 inside that strut keeps it pretty well oiled for plain old air. OK. Besides, nitrogen comes out the spigot at a pretty good pressure, and you can adjust an air compressor down to where it won't blow the piston out the bottom of the strut. We use nitrogen by adjusting the pressure with a relief valve upstream of the schrader before inflating the strut. Nitrogen is cheap and so is the relief valve. A nitrogen bottle without a relief valve could be dangerous, or I guess even more dangerous than it already is because of the high pressure. Have a good cross-country, now, heah? Jim " jls" wrote in message .. . These are the most wonderfully engineered oleo struts in the world. They are easy to rebuild and easy to service. Filling one with 5606 hydraulic fluid, however, is not best done by the book. You slip a tube which fits tightly over the schrader (with the stem removed) and the other end of the tube into your can of red hydraulic fluid. Then you pull out the collapsed strut to its full extension, thereby sucking 5606 fluid into the hollow strut. |
| Thread Tools | |
| Display Modes | |
| 1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 04:40 PM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 01:57 AM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 01:57 AM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Products | 1 | November 4th 03 01:57 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
