FAR Part 97: Aircraft Approach Categories - IAS vs Ground Speed
Old July 16th 05, 06:01 PM
Steven P. McNicoll
wrote in message ...
The values are there to be used as IAS or ground speed; it is pilot
option.
How can that be an option? There can be significant differences between
them.
Jeppesen is making an assumption that is not a regulatory charting value.
If the values are the same on NACO and Jeppesen charts, and if Jeppesen uses
GS as you say, then it should be clear that NACO uses GS as well.
Whatever made you think they were IAS anyway?
  #42
Old July 16th 05, 06:02 PM
Steven P. McNicoll
"Roy Smith" wrote in message
Oh, come on, this is getting silly. The table is labeled (for example, on
the HPN NDB 16) "FAF to MAP 4.8 NM". That's one point on the ground to
another point on the ground.
Well, the NDB is on the ground, nut the MAP is in the air! : )
  #43
Old July 16th 05, 09:23 PM
Judah
"Steven P. McNicoll" wrote in
k.net:
example, on the HPN NDB 16) "FAF to MAP 4.8 NM". That's one point on
the ground to another point on the ground.
Actually, technically speaking, the MAP is a fixed point in space that
happens to be physically above the ground. Howver, it is a fixed point at a
fixed altitude and at a fixed position relative to objects on the ground.
The real question here is, does the NACO chart take into consideration the
relative motion of the earth along it's axis when calculating ground speed?
And if so, do the times change based on the season?
  #45
Old July 16th 05, 09:25 PM
Roy Smith
k.net:
Don't forget continental drift.
  #46
Old July 17th 05, 06:45 AM
Jose
Actually, technically speaking the MAP is a moving point in space that
happens to be (defined to be) moving at the same rate as the ground.
flee Jose
Nothing takes longer than a shortcut.
  #47
Old July 17th 05, 07:18 AM
Steven P. McNicoll
"Jose" wrote in message
news
That would make it a fixed point in reference to the earth. Frame of
reference, dear boy, frame of reference.
  #48
Old July 17th 05, 02:28 PM
Jose
Frame of
Precisely. The poster didn't give one.
Jose
  #49
Old July 17th 05, 06:56 PM
Doug
My CFII didn't really understand holds. He knew how to enter them and
fly them. But he didn't know how ATC called them out and had some other
misunderstandings about them. But, him not knowing the facts on this
subject made ME research holds and other related subjects, so I'll
NEVER forget them now!!
  #50
Old July 17th 05, 07:26 PM
Steven P. McNicoll
Yes he did.
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
