#21
"Michael" wrote in message ups.com... ....snip... It is the avionics master is off during engine start to keep spikes from getting to the avionics. I suspect that's the cause of the OWT. In airplanes lacking an avionics master, optimal procedure is to shut down the avionics prior to engine shutdown and turn them on only after engine start. In cars this is accomplished by means of an automatic contactor, but in the aviation world we're not up to that level of technology. I am reading from the generic POH for 1976 Cessna 172, section 7, Airplane and Systems Descriptions, Electrical System: quote: Both sides of the bus are on at all times except when either an external power source is connected, or the *starter switch is turned on*; then a power contactor is automatically activated to open the circuit to the electronic bus. Isolating the electronic circuits in this manner prevents harmful transient voltages from damaging the transistors in the electronic equipment. :unquote. |
I take it back. I guess on some airplanes we ARE up to the basic
automotive level of technology. I've never owned a Cessna, and the Pipers I've owned had no such cutout. Michael |
"JohnH" wrote in message ... Jose wrote: On an aircraft with separate "battery" and "alternator" switches, should you turn on BAT and leave ALT off during engine start, or should you turn them both on prior to start? I leave alt off during start, to prevent a power surge from going through the alternator. What would be the source of this surge? If it's such a problem, why don't automobiles have alternator switches? Many do but it is automatic. They don't power the buss for a second or two after start to allow the alternator circuit to stabilize. |
"Icebound" wrote in message
... I am reading from the generic POH for 1976 Cessna 172, section 7, Airplane and Systems Descriptions, Electrical System: quote: Both sides of the bus are on at all times except when either an external power source is connected, or the *starter switch is turned on*; then a power contactor is automatically activated to open the circuit to the electronic bus. Isolating the electronic circuits in this manner prevents harmful transient voltages from damaging the transistors in the electronic equipment. :unquote. By 1981, though, the 172P POH says: "The primary bus is on anytime the master switch is turned on, and is not affected by starter or external power usage. Both bus bars are on anytime the master and avionics power switches are turned on." Perhaps Cessna decided that the electric-cutout switches created an unnecessary risk of accidental loss of electricity. --Gary |
| Thread Tools | |
| Display Modes | |
| What does REC mean on the switch? | Jose | Piloting | 10 | June 15th 05 06:55 AM |
| C-172 landing light switch | JFLEISC | Piloting | 16 | May 6th 04 02:15 AM |
| C-172 landing light switch | JFLEISC | Owning | 10 | May 6th 04 12:05 AM |
| C172SP engine start with battery switch only? | Robert Winn | Piloting | 8 | April 13th 04 01:31 AM |
| ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 09:40 PM |
