"Ross Magnaldo" wrote
You have confused me even more! If I am flying a radial with a cross wind, should the HDG bug be on the radial or should it be on the estimated course made good with the wind correction? Contrary to other answers you are getting, the correct procedure (where it matters) is to set the heading bug to the estimated course made good. The reason is as described - when there is a crosswind, if you set the radial you will actually fly an offset course. Whether it matters or not is another story. Every autopilot is, at the core, a wing leveler. If attitude based, it uses an attitude gyro with pickups to establish wings level. If rate based, it uses a TC with pickups to establish zero turn/roll. That zero is the setpoint - if you're not banking you shouldn't be turning (if trimmed). Note that a T&S is NEVER used - the response time is too slow, and a significant bank can be established before the autopilot knows it. For that reason, I always find it amusing when people tell me they prefer the old needle and ball for partial panel flying, but that's another discussion. Heading hold does not eliminate the basic wing leveler function - it alters it. The heading offset is used to change the setpoint of the wing leveler. A common setting is 1 degree of heading per degree of roll, with a 25 degree limit. That means that if the heading bug is 5 degrees to the right of the heading being flown, then instead of trying to maintain wings level the autopilot will try to maintain a 5 degree bank to the right. But if the heading bug is 45 degrees to the right of the heading being flown, the autopilot will try to maintain a 25 degree bank (the limit) to the right. If a rate based wing leveler is used, then it is usually set to treat a standard rate turn as being equivalent to anywhere from 15 to 30 degrees of roll, and limits the turn rate to standard rate. For general reference, the Century I and derivatives are rate-based, as are the S-TEC's. Most everything else is attitude based. To the user, it hardly matters (other than knowing which gyro to monitor to ensure the autopilot isn't doing something ugly). From here on in I'm going to assume an attitude based autopilot, but it all carries over to rate based ones. When you add in nav tracking, it gets interesting. Some autopilots use the CDI to directly drive the attitude set point, just like heading is used. What this means to you is that if the CDI is right of center, the plane will stay in a right bank until the CDI centers, with a bank proportional to CDI deflection (up to some limit, like 25 degrees bank or standard rate). The built-in assumption is that if the needle is centered, you are on the correct heading, and if it's not, you're not. Now, if I had a buck for every time I told an instrument student that just because the needle is centered DOESN'T mean you're on the right heading... Still, it tends to work OK tracking a LOC because the response is so quick - because the LOC needle is VERY sensitive. It also tends to work OK tracking a GPS, because the needle is almost as sensitive - if you don't mind the constant wing wobble in turbulence. If tracking a VOR in turbulence, it just doesn't work. Therefore most of the older autopilots (designed before everyone had GPS) don't use the CDI output directly - they use it to modify the heading error output. In other words, it flies like you would. For example, say the heading is dead on the bug, the wings are level, but the CDI is a dot left. This will generally be treated the same as if the bug was 5 degrees left of heading. The plane will bank 5 degrees left and start to turn. As the heading deviation increases to 1 degree left, the bank will be reduced to 4 degrees. In other words the autopilot will make an asymptotic turn - a technique that you would be well advised to master if you are ever going to fly partial panel in something fast and slippery. As the CDI approaches center, the plane will turn back to the bug - again, asymptotically. Some autopilots (the older Century II and III come to mind) do it both ways - depending on how you set the nav converter, they will or won't use the heading data in tracking the nav signal. Generally, they will not use the heading data in approach mode (because the CDI is presumed to be sufficiently sensitive, and the response sufficiently quick) but WILL use it for enroute nav. OK, now how do you figure out which kind you have? Easy. Get the plane on course and on heading, set the heading bug to the heading you are flying, make sure the CDI is centered, engage autopilot in nav track mode. Once you are satisfied it is tracking, give the heading bug a big ol' twist - say 45 degrees. If the plane tries to follow the bug initially, you know the heading data is being used in that mode. If it doesn't twitch, it's not. Michael Please do not send email replies to this posting. They are checked only sporadically, and are filtered heavily by Hotmail. If you need to email me, the correct address is crw69dog and the domain name is this old airplane dot com, but remove the numbers and format the address in the usual way. |
Thanks Michael for the clarity of the explanation.
The autopilot I'm using (when it wants to work) is rate based - I'll check it next time for the VOR heading. Fly safely, Ross "Michael" wrote in message om... "Ross Magnaldo" wrote You have confused me even more! If I am flying a radial with a cross wind, should the HDG bug be on the radial or should it be on the estimated course made good with the wind correction? Contrary to other answers you are getting, the correct procedure (where it matters) is to set the heading bug to the estimated course made good. The reason is as described - when there is a crosswind, if you set the radial you will actually fly an offset course. Whether it matters or not is another story. Every autopilot is, at the core, a wing leveler. If attitude based, it uses an attitude gyro with pickups to establish wings level. If rate based, it uses a TC with pickups to establish zero turn/roll. That zero is the setpoint - if you're not banking you shouldn't be turning (if trimmed). Note that a T&S is NEVER used - the response time is too slow, and a significant bank can be established before the autopilot knows it. For that reason, I always find it amusing when people tell me they prefer the old needle and ball for partial panel flying, but that's another discussion. Heading hold does not eliminate the basic wing leveler function - it alters it. The heading offset is used to change the setpoint of the wing leveler. A common setting is 1 degree of heading per degree of roll, with a 25 degree limit. That means that if the heading bug is 5 degrees to the right of the heading being flown, then instead of trying to maintain wings level the autopilot will try to maintain a 5 degree bank to the right. But if the heading bug is 45 degrees to the right of the heading being flown, the autopilot will try to maintain a 25 degree bank (the limit) to the right. If a rate based wing leveler is used, then it is usually set to treat a standard rate turn as being equivalent to anywhere from 15 to 30 degrees of roll, and limits the turn rate to standard rate. For general reference, the Century I and derivatives are rate-based, as are the S-TEC's. Most everything else is attitude based. To the user, it hardly matters (other than knowing which gyro to monitor to ensure the autopilot isn't doing something ugly). From here on in I'm going to assume an attitude based autopilot, but it all carries over to rate based ones. When you add in nav tracking, it gets interesting. Some autopilots use the CDI to directly drive the attitude set point, just like heading is used. What this means to you is that if the CDI is right of center, the plane will stay in a right bank until the CDI centers, with a bank proportional to CDI deflection (up to some limit, like 25 degrees bank or standard rate). The built-in assumption is that if the needle is centered, you are on the correct heading, and if it's not, you're not. Now, if I had a buck for every time I told an instrument student that just because the needle is centered DOESN'T mean you're on the right heading... Still, it tends to work OK tracking a LOC because the response is so quick - because the LOC needle is VERY sensitive. It also tends to work OK tracking a GPS, because the needle is almost as sensitive - if you don't mind the constant wing wobble in turbulence. If tracking a VOR in turbulence, it just doesn't work. Therefore most of the older autopilots (designed before everyone had GPS) don't use the CDI output directly - they use it to modify the heading error output. In other words, it flies like you would. For example, say the heading is dead on the bug, the wings are level, but the CDI is a dot left. This will generally be treated the same as if the bug was 5 degrees left of heading. The plane will bank 5 degrees left and start to turn. As the heading deviation increases to 1 degree left, the bank will be reduced to 4 degrees. In other words the autopilot will make an asymptotic turn - a technique that you would be well advised to master if you are ever going to fly partial panel in something fast and slippery. As the CDI approaches center, the plane will turn back to the bug - again, asymptotically. Some autopilots (the older Century II and III come to mind) do it both ways - depending on how you set the nav converter, they will or won't use the heading data in tracking the nav signal. Generally, they will not use the heading data in approach mode (because the CDI is presumed to be sufficiently sensitive, and the response sufficiently quick) but WILL use it for enroute nav. OK, now how do you figure out which kind you have? Easy. Get the plane on course and on heading, set the heading bug to the heading you are flying, make sure the CDI is centered, engage autopilot in nav track mode. Once you are satisfied it is tracking, give the heading bug a big ol' twist - say 45 degrees. If the plane tries to follow the bug initially, you know the heading data is being used in that mode. If it doesn't twitch, it's not. Michael Please do not send email replies to this posting. They are checked only sporadically, and are filtered heavily by Hotmail. If you need to email me, the correct address is crw69dog and the domain name is this old airplane dot com, but remove the numbers and format the address in the usual way. |
| Thread Tools | |
| Display Modes | |
| Details on Wittman Buttercup | Charlie | Home Built | 1 | November 25th 03 05:19 AM |
| Looking for a home for C130 autopilot amplifier... | tongaloa | Home Built | 0 | August 18th 03 07:44 PM |
| Kinda OT but... Trying to flog a Sperry SP 20 autopilot servo ampfor C130... | tongaloa | Home Built | 0 | August 8th 03 08:45 PM |
| Oshkosh Rec.Aviation Get-together details... | Jay Honeck | Home Built | 2 | August 3rd 03 05:31 PM |
