Good question. Make sure it's tight and then safetied with a small
bolt and castellated nut when you put it on. No beating,whacking, or hammering. Don't wallow out the rod holes in the hub nut. Use a snug-fitting long rod. The crankshaft is tapered. So is the female hub. Those crankshafts and hubs should also be magnafluxed before being put back into service. The keyway for the woodruff key is susceptible to cracks. Have you checked for cracks? Also make sure you have a lockring which secures the nut to the hub, or when you remove the hub down the road, you'll have the devil getting it off. I don't know how many of those hubs I've seen without lockrings. Check the hub for runout. |
| Thread Tools | |
| Display Modes | |
| Proper Torque for Fuel Fittings | Steve Waltner | Home Built | 10 | February 20th 05 01:46 AM |
| Continental IO-520A operating data? | Michael | Owning | 7 | November 26th 04 09:38 PM |
| Bolt torque | Neal Fulco | Home Built | 1 | October 16th 04 07:57 AM |
| Continental Airlines Complaint - A Newspaper article | John B. | Piloting | 40 | October 21st 03 05:07 PM |
| Prop bolt torque setting | Whunicut | Home Built | 2 | September 4th 03 01:12 PM |
