O-360 takeoff power fuel flow question
Old July 25th 05, 08:45 PM
Michael
18 GPH is maximum allowable fuel flow for an O-360 at 2700 RPM at sea
level and standard conditions (higher fuel flows work, but cause some
loss of power).
16 GPH is maximum allowable for an O-320 under the same circumstances.
These are maximum values; minimum values are as much as 13% lower. 16
GPH would be within tolerances. 15.5 would be a bit on the low side,
but only VERY slightly, as in 1% low. It's not rare for a JPI to be
1%-2% off on fuel flow.
Some other things you should consider:
Are you at sea level? Fuel flow should decrease as air density
decreases.
Are you really making 2700 RPM? Unless you've checked with an
electronic tach, you don't know. Mechanical tachs are notoriously
inaccurate.
Michael
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 08:04 PM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 03:21 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 10:47 PM
