In fact, the presenting problem is that I have not been solidly below
400=B0F. The hottest peak CHT just after takeoff on a standard day would be more like 430=B0F, and the coolest about 400=B0F. On really hot days I have seen even higher values, albeit for only a short time. I think I have solved this problem at this years's annual by installing a fairing around the big gap between the PowerFlow exhaust pipe (much smaller than the standard Cessna exhaust). With the fairing installed, peak CHTs just after takeoff are now between 400=B0F and 375=B0F as a result of better airflow inside the cowling. Regarding design limits, I do appreciate that Deakin was referring to bigger engines. But I still wonder what a limit for the O-360 might be as a result of adding the tuned exhaust. One step at a time, let's check the prop governor and maybe the wide-open mixture. Thanks. |
| Thread Tools | |
| Display Modes | |
| Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 08:04 PM |
| Fuel dump switch in homebuilt | Jay | Home Built | 36 | December 5th 03 03:21 AM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
| Question ~ Does fuel injection add weight? | Barnyard BOb -- | Home Built | 0 | July 6th 03 10:47 PM |
