#11
"Gary Drescher" wrote in message ... Correct, provided that an instrument letdown is necessary (ie, you're in IMC). What about a contact approach? One could even argue that a visual approach can be flown in IMC since VFR cloud clearance requirements do not apply. |
. net... "Gary Drescher" wrote in message ... Correct, provided that an instrument letdown is necessary (ie, you're in IMC). What about a contact approach? One could even argue that a visual approach can be flown in IMC since VFR cloud clearance requirements do not apply. Good point. |
"Gary Drescher" wrote: "Steven P. McNicoll" wrote in message . net... "Gary Drescher" wrote in message ... Correct, provided that an instrument letdown is necessary (ie, you're in IMC). What about a contact approach? One could even argue that a visual approach can be flown in IMC since VFR cloud clearance requirements do not apply. Good point. No, bad point. Steven knows that neither a visual approach nor a contact approach is legal in IMC. He's just being deliberately obfuscatory, as usual. |
"Roy Smith" wrote in message ... No, bad point. Steven knows that neither a visual approach nor a contact approach is legal in IMC. He's just being deliberately obfuscatory, as usual. Please explain how they're illegal in IMC. |
... No, bad point. Steven knows that neither a visual approach nor a contact approach is legal in IMC. A contact approach requires only 1sm visibility. That's certainly IMC in class B, C, D, or E. --Gary |
"Gary Drescher" wrote: "Roy Smith" wrote in message ... No, bad point. Steven knows that neither a visual approach nor a contact approach is legal in IMC. A contact approach requires only 1sm visibility. That's certainly IMC in class B, C, D, or E. --Gary Sigh. I knew I shouldn't have responded to that because we'd get into something like this. By IMC I meant "in cloud". |
"Roy Smith" wrote in message ... Sigh. I knew I shouldn't have responded to that because we'd get into something like this. By IMC I meant "in cloud". Then you used the term incorrectly. IMC does not mean "in cloud", it means "meteorological conditions expressed in terms of visibility, distance from cloud, and ceiling less than the minima specified for visual meteorological conditions." |
... It does more than suggest, it states it quite explicitly (for most of us, neither of the exceptions are likely to apply): "Unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in part 97 of this chapter." So the next question, which I'll ask on Peter's behalf is... Since Part 97 only prescribes approaches for airports within the US (and presumably associated territories), how does an N-registered aircraft ever fly an IAP in IMC outside the US? Julian |
"Peter" wrote in message ... This could be any of MEA, MOCA, MRA? It couldn't be an MRA. An MRA is simply the lowest altitude at which an intersection can be determined and should always be above the MEA/MOCA. Would the pilot be free to choose the lowest? The pilot would comply with his clearance. |
"Julian Scarfe" wrote in message ... So the next question, which I'll ask on Peter's behalf is... Since Part 97 only prescribes approaches for airports within the US (and presumably associated territories), how does an N-registered aircraft ever fly an IAP in IMC outside the US? Probably by being otherwise authorized by the Administrator. |
| Thread Tools | |
| Display Modes | |
| Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 03:41 AM |
| Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 03:16 PM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| Most Challenging Instrument Approaches in Western US? | Angus Davis | Instrument Flight Rules | 24 | September 28th 03 10:25 AM |
| Logging instrument approaches | Slav Inger | Instrument Flight Rules | 33 | July 28th 03 12:00 AM |
