#11
"Gordon Arnaut" wrote in message ... Ha, ha, ha...another chestnut from the avionics Hemingway of Kitplanes. Regards, Gordon. PS: For anyone out there that might still be interested in serious discussion of wood, I want to just add a little about compressive strength and tensile strength as it relates to wood species substitution. Using the same FPL data I used earlier, we see that spruce has a maximum crushing strenght of 5,650 psi, while pine is 4840 psi, which makes pine exactly 85 percent as strong in compression. This is nearly the same difference as in bending -- and as I noted earlier, most of the other measures will be similarly in line. But just to see if my statement that 7/8' pine will adequately substitute for 3/4 spruce, let's calculate. Since stress is force per area, we can see that a 3/4" spruce member will be able to withstand a maximum compressive stress of 0.75(squared) x 5650 = 3178 psi. How big would our pine member have to be? Well by rearranging the formula 3178 divided by 4840 will give us the dimension squared, which is 0.81 inch, again somewhat less than 7/8". So just as in the bending moment calculation we see that substituting 7/8' pine for 3/4" spruce gives us a member that is actually a little bit stronger. It is also a tiny bit heavier, but this is negligible. However I should point out that going through the exercise we just did is not proper methodology. I am only doing it to prove a point. The proper method is to first identify the structural member we are interested in analyzing, like I did with the wing spar. Next we have to know how much load this member is expected to carry. Only then does it make sense to determine the size of the member. But like I said, let's see if Mouth-Foamer can tell us which pieces of the plane are under pure compression or tension. (Since he is so concerned aobut that and is basing his whole character assassination on me on that stupid notion). In the meantime, I hope Mr. Personality is getting the couch-time he so desperately needs. And I hope he doesn't forget to remind his analyst, "first do no harm." And,,,,,, who gives a f***ck |
| Thread Tools | |
| Display Modes | |
| Sensenich Wood Prop Question | [email protected] | Owning | 3 | April 4th 05 03:32 PM |
| wood grain question. | Fred the Red Shirt | Home Built | 1 | December 6th 04 03:13 PM |
| Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 08:45 PM |
| Wood questions - Public Lumber Company, determining species at the lumberyard | Corrie | Home Built | 17 | September 17th 03 07:51 PM |
