Agreed. A full stall landing isn't a good idea on floats, because it means
you come down on the tail of the floats -- and this could mean pitching sharply forward and possibly going up and over. Instead, you want to settle at minimum sink rate on the step, regardless of whether it's water, grass, snow, plowed field or pavement, and come to as gradual a stop as possible using the keels as your brakes. Which is exactly what happened in this case. Bravo. Seth "Peter Duniho" wrote in message ... "Flyingmonk" wrote in message oups.com... Maybe the floats were damaged, but remained in corrrect position/alignment until the weight was applied on touchdown and it gave way? The report I saw said that the floatplane pilot noted the floats at an angle before touchdown. As far as the "hung it on a prop and 'three-pointed' it" goes...witness accounts say that the floatplane bounced several times before coming to a rest. It sounds to me like a classic example of the pilot continuing to fly the airplane until it came to a stop, no matter what happened. This is, of course, the text-book example of what one SHOULD do when landing, in an emergency or otherwise. ![]() I think it likely that the successful landing had less to do with a particular choice of technique, and more to do with a pilot who kept his wits about him and maintained control of the airplane as best he could, even in an extremely difficult situation. Pete |
at minimum sink rate on the step, regardless of whether it's water, grass... What does "on the step" mean outside of a water landing? Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
It means the first point of contact with the earth's surface should be the
strongest part of the keel: that is, the step. Touch down anywhere else and you risk a flip-over. Deceleration is going to rock you forward onto the forward keel, and you want that pitch-over to happen as slowly and gently as possible. So if I were doing it I'd probably apply gentle up-elevator as soon as the step made contact. In fact this process should be a lot like a soft-field landing in a plane with wheels. Any float CFIs out there feel differently? Seth "Jose" wrote in message ... Instead, you want to settle at minimum sink rate on the step, regardless of whether it's water, grass... What does "on the step" mean outside of a water landing? Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
Seth Masia wrote:
Agreed. A full stall landing isn't a good idea on floats, because it means you come down on the tail of the floats -- and this could mean pitching sharply forward and possibly going up and over. Instead, you want to settle at minimum sink rate on the step, regardless of whether it's water, grass, snow, plowed field or pavement, and come to as gradual a stop as possible using the keels as your brakes. Which is exactly what happened in this case. Bravo. Have you *seen* the photos? There's no way you could bring that plane down on the tail of the floats. The miracle is that the noses didn't dig into the grass. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
No, I didn't see the photos. I'm just talking about floatplanes in
general -- stalling at low altitude is the last thing I'd want to do in a floatplane, for exactly this reason. Do you have a link to the pix? Seth "George Patterson" wrote in message news EcJe.4152$eR.3067@trndny04...Seth Masia wrote: Agreed. A full stall landing isn't a good idea on floats, because it means you come down on the tail of the floats -- and this could mean pitching sharply forward and possibly going up and over. Instead, you want to settle at minimum sink rate on the step, regardless of whether it's water, grass, snow, plowed field or pavement, and come to as gradual a stop as possible using the keels as your brakes. Which is exactly what happened in this case. Bravo. Have you *seen* the photos? There's no way you could bring that plane down on the tail of the floats. The miracle is that the noses didn't dig into the grass. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Seth Masia wrote:
No, I didn't see the photos. I'm just talking about floatplanes in general -- stalling at low altitude is the last thing I'd want to do in a floatplane, for exactly this reason. Do you have a link to the pix? Try http://images.ibsys.com/2005/0805/4812340_400X300.jpg George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
| Thread Tools | |
| Display Modes | |
| Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 03:39 AM |
| Parachute saves light plane's passengers | randall g | Piloting | 0 | April 9th 04 08:42 PM |
| The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 01:07 PM |
