TSIO 360 EB running lean at 12000
Old August 7th 05, 08:56 PM
Kyle Boatright
Several questions:
What do you mean by hot? What were the CHT's and Oil Temperatures? What do
they normally run?
What % of full power is 29" and 2400 RPM? I realize you're flying a
turbocharged aircraft, but 24" and 2400 RPM is usually something like 75%,
so I'd guess 29" and 2400 RPM is well over 75%.
What is the recommended max cruise setting for these engines?
Am I correct in assuming these are Continental 210 hp engines?
"Silvio Mecucci" wrote in message
Hi all,
Yesterday I was flying on a Seneca II equipped with TSIO 360EB Teledyne
Continental engines.
The first flight (Dusseldorf-Milan) took 2 hours, FL 140, everything
working perfectly adn according to the manual.
The second flight (Milan-Rome) had the following inconvenience on BOTH
engines:
At FL 130 29" MAP 2400rpm the indicated fuel flow was 12 Gal/Hours
but the Mixture control lever were in the "Full Rich" position.
I could not move them to lean mixture since the fuel flow was going
down to less than 12. The speed was correct (about 170 KTAS), and the
engines were both a little bit too hot, but not that much.
I repeat it was behaving like this for BOTH engines. And this
sound strange and new to me..
I still have to fly again with the same plane, and it will be checked
by a specialist before, but, is there anybody who has an idea about
what was happening ?
Silvio
Leaning Procedure for a Carbureted 182 Jeffrey Owning 54 July 5th 05 05:23 PM
It's finally running! Corky Scott Home Built 19 April 29th 05 05:53 PM
Constant speed props GE Piloting 68 July 3rd 04 05:08 AM
Lean of Peak Test Flight Roger Long Piloting 0 April 22nd 04 11:13 AM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 05:56 PM
