On 7 Aug 2005 08:40:41 -0700, "Silvio Mecucci"
wrote: Please refer to TCM SID97-3C (latest revision is dated 2-25-2005). http://www.tcmlink.com/pdf2/SID97-3C.pdf It describes in detail how the fuel injection system on your engines is to be set-up. This should have been accomplished when your "new" engine was installed, and the unmetered pressures and fuel flows should be verified periodically (during scheduled inspections). I am not saying that you have a problem, but ensuring that you have the proper fuel delivered to a turbo-supercharged aircraft engine is not an option. Regards; TC Hi all, Yesterday I was flying on a Seneca II equipped with TSIO 360EB Teledyne Continental engines. The first flight (Dusseldorf-Milan) took 2 hours, FL 140, everything working perfectly adn according to the manual. The second flight (Milan-Rome) had the following inconvenience on BOTH engines: At FL 130 29" MAP 2400rpm the indicated fuel flow was 12 Gal/Hours but the Mixture control lever were in the "Full Rich" position. I could not move them to lean mixture since the fuel flow was going down to less than 12. The speed was correct (about 170 KTAS), and the engines were both a little bit too hot, but not that much. I repeat it was behaving like this for BOTH engines. And this sound strange and new to me.. I still have to fly again with the same plane, and it will be checked by a specialist before, but, is there anybody who has an idea about what was happening ? Silvio |
| Thread Tools | |
| Display Modes | |
| Leaning Procedure for a Carbureted 182 | Jeffrey | Owning | 54 | July 5th 05 05:23 PM |
| It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 05:53 PM |
| Constant speed props | GE | Piloting | 68 | July 3rd 04 05:08 AM |
| Lean of Peak Test Flight | Roger Long | Piloting | 0 | April 22nd 04 11:13 AM |
| Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 05:56 PM |
