fuel consumption Jabiru 3300
Old August 8th 05, 04:20 PM
John
karel wrote:
Out of curiosity I started to look for fuel consumption figures for the
Jabiru 3300.
I found a figure of 0.46 lbs/HP/hr which is not particularly meaningful to
me.
Moreover it said "at cruise power" without further specification.
So I started to assume 65% powser for cruise, calculating from
the rated power of 120HP this gives some 78 HP.
So 78*0.46 gives me 3.6 lbs/hour, or 6 USG per hour or close to 23
liters/hour.
Is this way of calculating correct and do the numbers seem reasonable?
I had expected this engine to be less fuel hungry than the Lycomings &C...
Do not Rotax claim something like 15 liters/hour?
TIA
PS do not tell me that the rated power of 120 HP is not for
continued application, I knew that. Seems similar to the Rotax 914S.
According to the Zenair web site: (seems a bit optimistic)
Specifications: Jabiru 3300 A
Displacement: 3300 cc. (200 cu.in.)
Bo 97.5 mm.
Stroke: 74 mm.
Compression: 8.3 : 1
Prop Rotation: Clockwise
Firing Order: 1 - 4 - 5 - 2 - 3 - 6
Power Rating: 100 hp @ 2750 rpm (see above)
Fuel Consumption @ 75%: 5.0 US Gal/Hour (gph)
Fuel: 100/130 Avgas or 92+ octane Mogas
Oil: Aeroshell W100 (or equivalent)
Oil Capacity: 3.5 qts. (3.75 l.)
Spark: NGK D9EA (common automotive)
My Cessna 150 manual (for a continental o-200) shows a spc of .448 for 75%
(75 HP) operation. The above table works out to a SFC of .4 which looks
low.( note they derate the J 3300 to 100 HP) your figure of .46 looks more
real. Hey but who knows unless you've flown one!
John
Old August 8th 05, 05:26 PM
jls
Default fuel consumption Jabiru 3300
"karel" wrote in message
Jabiru 3300.
me.
liters/hour.
TIA
Isn't that a six-banger with 3.3 liter displacement? I'm surprised it
doesn't use more fuel than that. It revs higher than your average Lycoming
or Continental too.
Old August 8th 05, 07:42 PM
ORVAL FAIRAIRN
Jabiru 3300.
me.
liters/hour.
Your method is correct -- but it is 36#/hr, not 3.6! Yes, it does work
out to about 6 gph. BTW, 0.46 #/hp/hr is right in the ballpark for
aircooled piston, gasoline engines.
Old August 9th 05, 03:51 PM
Joe McGaw
23 liters for the 3300cc Jairu is conservative. My 80hp 2200cc Jabiru
uses only 13 liters per hour at 2500rpm cruise revs.
Cheers,
Joe
liters/hour.
Old August 9th 05, 06:46 PM
Stealth Pilot
On Tue, 9 Aug 2005 15:21:44 -0000, "karel"
"Joe McGaw" wrote in message
Thank you, this is kind of useful information.
In what aircraft, please?
KA
ask jabiru direct in bundaberg.
www.jabiru.net.au is the web site.
if you call it up you will be able to get the specifications sheets in
pdf form.
just checking it now jabiru say that 26litres per hour at 75% power is
the consumption. varies with power used and prop installed.
Stealth Pilot
Australia
Old August 9th 05, 08:42 PM
A couple of weeks ago I traveled to Mexico MO to take a demo flight in
the Zenithair Zodiac 601XL. It had a Jabiru 3300 and according to the
factory pilot I flew with the fuel consumption was 6 GPH.
AZ
Old August 9th 05, 09:03 PM
Gig 601XL Builder
AZ
Did you go through the rudder workshop? What did you think? Are you a Zodiac
builder now?
Old August 9th 05, 09:55 PM
KA
A fellow by the name of Kerry Fores did some test flights to evaluate
the fuel consumption of his Sonex with the 3300. I believe it was
equipped with an Aerocarb. The results IMHO are quite amazing. If his
results are accurate with the 3300, I'd like to know what the results
would be with an Aerocarb equipped 2200. I got his article off the
Sonex website. I'll try to send the URL.
Neal
http://www.sonex-ltd.com/Sonex_35_Hamburger.html
Old August 10th 05, 01:38 AM
Dave S
Jabiru 3300.
me.
This is actually a pretty reasonable number. Most of the big bore
lycomings are in this range, if I remember the discussions I have had
recently on power and fuel consumption.
The value being discussed here is "BSFC" or brake specific fuel
consumption. This is part of the universal "truth" regarding horsepower
in internal combustion engines. HP takes fuel. More HP takes more fuel.
As others have already pointed out, you had one decimal out of place..
(36 pph) but the rest of the math was about right..
As for the 15 liter per hour claim.. that is likely the power setting
(and fuel flow) for max range/best economy. Airframe and engine
manufacturers like to "play" with the numbers to suit their needs. None
of this overrides the fact that you have to burn more fuel for more HP.
With a BSFC of 0.45 (essentially the same as your engine, and similar to
Lyc's and continentals). I am not positive at what mixture this is being
computed at, but stoichiometric (1:14.7) seems to be the most logical.
250 hp = 18.75 gal/hr
200 hp = 15 gal/hr
150 hp = 11.25 gal/hr
100 hp = 7.5 gal/hr
The way you can use this BSFC to your benefit is in evaluating engine
efficiency claims on your own, independently of marketing claims. Your
fuel burn for given power setting can be calculated.
If an engine maker, particularly a new-comer, wont release their values,
then their claims of power and efficiency should be viewed as suspect
and with skepticism.
Dave
TIA
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 08:04 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 11:20 PM
Question on fuel consumption Shemp McGurk Piloting 24 October 26th 04 12:50 AM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 07:13 PM
