Since Mooney's sit low, does this mean prop clearance is an issue?
Hence a short prop, hence a fat blade? You probably have it right. From my observations, prop design seems to be more of an art than a science. This topic is very confusing. An interesting aspect of prop design is not only the chord shape but also the number of blades. People generally think that more horsepower requires more blades. But witness the Piper Malibu's two-blader (350 hp) and the Piper Turbo Seminole's three-blader (180 hp). Mooney's Ovation was initially sold with a three blade prop but later changed to a two blade (Ovation 2) and it picked up 8 knots of airspeed. Evidently this was due to the efficiency gains of the two blade, the same reason it was chosen for the Malibu. I believe three bladers are preferred for their reduced vibration, quiter operation, greater low speed thrust, and appearance. Chord design probably is the main factor in determining the efficiency of the prop regardless of the number of blades. Frankie |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 08:45 PM |
| New Prop on my Mooney Ovation | Charles Talleyrand | Owning | 1 | July 7th 03 11:30 PM |
