smoothing rough concrete hangar floor?
Old August 19th 05, 01:28 AM
Roger
On Tue, 16 Aug 2005 09:48:51 -0400,
On 15 Aug 2005 22:34:35 -0700,
We put in a concrete hangar floor and the finish is less than
desirable. There are patches where it's recessed (about 1/8"- 1/4"
recessed and rough) and then other areas where it's rough and proud
(about 1/8") with swirl marks.
That's a lot more than I'd expect for a "broom finish".
Is there anything we can do to mechanically smooth this? Do they make
a big sander for concrete and how well does it work?
There is a product called "ARDEX" that was used inside to smooth out a
rough finished concrete floor. It's fairly easy to use in that you
mix it and then simply pour over the floor allowing it to settle in
and level out. When it cures, the surface is smooth.
One thing to remember when using this kind of product. The floor
needs to be very close to level over all. You definitely will find
the high and low spots.
When I acid etched the shop floor and then pressure washed it I found,
contrary to what was supposed to be) the low spot was centered on the
south wall instead of at the East end at the large door. Still the
floor must be within a 1/4" over all. I don't consider that bad for a
28 X 40 foot floor.
It was used inside an occupied building and did not have much of an
odor to it.
The two part epoxy garage/shop floor finish not only smells, but it's
bad for you and it's explosive.
www.rogerhalstead.com
Corky Scott
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Instrument Flight Rules 10 April 19th 04 12:37 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar General Aviation 1 April 6th 04 07:17 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Home Built 0 April 6th 04 12:57 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Home Built 0 April 6th 04 12:56 AM
Rules on what can be in a hangar Brett Justus Owning 13 February 27th 04 05:35 PM
