Oil lines as electrical ground return?
Old September 4th 05, 11:01 PM
Scott Derrick
Default Oil lines as electrical ground return?
I accidently wrote my first post as a reply to another thread, so here
it is again on its own.
I have a pusher airplane with a nose oil cooler.
I am replacing the existing heavy hydraulic type(rubber/braided steel)
oil cooler lines with lighter metal lines. Either soft Aluminum or soft
copper 1/2 lines.
First question. I would like to use the lines as my ground return and
remove the 2 AWG wire I have now. Good idea?
Second question. Which would be better, or possibly which would be
worse and why? Copper or Aluminum.. Aluminum would be lighter but
copper offers a better ground return(less resistance). I have a big
engine and the starter needs all the current I can muster.
Scott
Old September 5th 05, 12:57 AM
COLIN LAMB
Second question. Which would be better, or possibly which would be worse
and why? Copper or Aluminum.. Aluminum would be lighter but copper offers
a better ground return(less resistance). I have a big engine and the
I would not substitute the brake line for the #2 ground return. Beware of
corrosion that may occur in any connections that join copper and aluminum.
There is a potential difference, and the voltage created causes corrosion.
In some cases, the corrosion could continue until something bad happens -
including loss of electrical system. Any weight saving would be false
economy.
I would use copper rather than aluminum. Aluminum is less weight, but it
requires more preparation to connect. Keep everything in copper. If copper
touches aluminum, you will get electrolysis unless a special goop is used
with an approved connector.
Colin
Old September 5th 05, 04:40 PM
jerry wass
copper 1/2 lines.
Scott
IF--you decide on the copper lines--do this--take a strip of bar copper
about 1/8" thick, 3/4" wide, and a couple of inches long..drill a 5/16"
hole in one end, form the other into a portion of a circle that is a
snug fit around the tubing---clean & silver solder the strap around the
tube..repeat at other end---This way if you get a loose connection, you
won't burn a hole in the tube.. Get a couple of MS-xxxx male flare
fittings--bore the other end out to a slip fit on the copper be sure &
leave the hex fitting on the adapter, so you can TIGHTEN the flex
hose.---Again, silver solder them on the tubing.
use SS braided Teflon lined hoses to complete the plumbing---allow for
expansion of the length of the tube..&&&& Jerry
Toronto Area Glider Pilot Ground School Starts Thu. February 24, 2005 Ulf Soaring 0 February 3rd 05 07:16 PM
tuned ground plane John Tvedte Home Built 13 November 27th 04 07:09 PM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 01:27 PM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 06:11 AM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
