what the heck is lift?
Old September 9th 05, 03:57 PM
Jimbob
On Fri, 09 Sep 2005 14:29:18 +0200, Thomas Borchert
Wings generally tend to have a curved suface. The upper surface has a
greater arc or curvature than the lower surface. As the air flows across the
surfaces of the wing, the upper surface air is forced to move faster than
the lower surface air thus causing a pressure difference between the two
surfaces.
Forced by what? And how does your "theory" explain inverted flight? I don't
buy it.
BTW, this has been beaten to death in countless aviation newsgroup
discussions. I once thought like you, because I was taught that way. It's
still a bad theory. I suggest googling. Keywords might be: lift, flight,
Bernoulli, Newton.
He is describing the traditional airfoil theory which is correct. It
is the most efficient method as it produces lift with minimal drag.
That's what most people are taught.
There is another mode that is related to the force of the air
impacting on the bottom of the wing at high AOA producing lift as
well. Think of your control surfaces. Your rudder control surface is
symmetric, yet it produces horizontial components of force. IIRC, the
Jeppesen books cover high AOA effects as well.
Inverted flight is accomplished by the second of the two effects.
They have to fly at a higher AOA relative to normal flight to
compensate for the airfoil effect. Some aerobatic planes have
symmetric airfoils for this reason.
As AOA increases, the deflection takes more of a role. At stall, the
deflection is suffcient for the airfoil effect to be interfered with
and ceases. Thus a large component of left is lost. You drop. You
still have some lift, but it is not sufficient to keep you airborne.
http://www.unconventional-wisdom.org
Old September 9th 05, 04:20 PM
Thomas Borchert
Jimbob,
Uhm, no.
Thomas Borchert (EDDH)
Old September 9th 05, 05:19 PM
Gone Flyin'. -----==0==-----
Uhm, no.
Oh uhm, YES!
Old September 9th 05, 06:22 PM
Greg Copeland
On Fri, 09 Sep 2005 13:57:30 +0000, Jimbob wrote:
[snip]
Isn't this the theory behind lifting bodies (aka, Space Shuttle) and why
many low wing planes tend to generate some minor amount of lift across the
fuslage area, in between the root coords?
[snip]
Old September 9th 05, 07:26 PM
Margy
surfaces.
buy
Forced by limiting the space through which the fluid must flow. Think
of your garden hose. If you put your thumb over the end and constrict
the space the water flows faster through the opening. As the speed
increases the pressure decreases, air moves from high pressure to low
pressure and the wing of the airplane is in the way of this movement so
it is lifted up with the high pressure air. This also explains wing tip
vortices and why for a given configuration a higher aspect ratio wing
will produce more lift than a lower aspect ration wing.
Inverted flight and equal camber wings use AOA to create the air
pressure differential.
Margy
Bernoulli, Newton.
Old September 9th 05, 08:25 PM
john smith
PV=nRT
Old September 11th 05, 12:09 PM
Montblack
("Margy" wrote)
[snip]
Forced by limiting the space through which the fluid must flow. Think of
your garden hose. If you put your thumb over the end and constrict the
space the water flows faster through the opening. As the speed increases
the pressure decreases, air moves from high pressure to low pressure and
the wing of the airplane is in the way of this movement so it is lifted up
Garden hose + thumb:
"As the speed increases the pressure decreases..." part throws me. As the
flow increase?
C'mon over here and explain it again please. Yes, yes. Of course I'll keep
the hose kinked --- almost in range. hehehe
Montblack
Old September 9th 05, 03:41 PM
buttman
Gone Flyin'. -----==0==----- wrote:
It's also worth noting that
VNE decreases with altitude.
Actually, it's not. the true airspeed at which VNE occurs is greater as
altitude increases, but the calibrated aurspeed (VNE is defined as a
calibrated airspeed) remains the same regardless of altitude.
Old September 9th 05, 03:29 PM
Brien K. Meehan
buttman wrote:
He said that lift is directly and
soley related to AOA and AOA only. So if you are doing slow flight, you
are producing more life than you are when you're cruising.
So, if follows that if I stand my airplane on its tail, sitting on the
ground with an airspeed of zero, it's producing the maximum amount of
lift possible.
Old September 9th 05, 03:45 PM
buttman
Thats what I told him. This guy is an amazing instructor. He's an MEI
and a CFII with a ton of CFI and CFII singoffs. I was just wondering if
we were thinking of two different concepts. My definition of lift being
different than his...
Lift Query Avril Poisson General Aviation 8 April 21st 05 08:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 05:08 PM
New theory of flight released Sept 2004 Mark Oliver Piloting 70 October 10th 04 11:50 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 11:55 PM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 09:52 PM
