"Stefan" wrote in message ... Is anyone doing this? In Europe, this is becoming more and more common. Towing works astonishingly well with 100 hp and one of those new planes. The limit is when the glider is very heavy (fully loaded two seater) or the runway is very short and soft. Towing with 3 gal/hour and with remarkably little noise is much cheaper and neighbour-friendlier, even if a tow it last 10% longer. There are currently two categories of "new tow planes": Motorgliders (such as the Super Dimona, in the USA called Katana XTreme) and modern ultalights, as they are called here (see for example http://www.remos.com/). All in all, in Europe we strongly believe that this is the future of towing. Stefan I don't believe an optimum design tow plane would look anything like a touring motorglider. The key to performance and economy is the propeller. It should be really big and slow turning. Remember, propeller blades are just rotating wings. They work best at the L/D max just like a sailplane. Think of a three to four meter diameter prop turning at 1000 RPM. The touring motorglider airframes won't accommodate a prop that big. I'm thinking of something that would look like an oversize ultralight with the pilot way forward for the best view and a pusher prop over a low wing. The wing would baffle what little sound the prop made so it should be very quiet. A very slow prop could be easily driven with a tooth belt. 130 HP should be more than enough for the heaviest 20 meter two-seater. A water cooled Honda or Subaru engine might work great. Bill Daniels |
| Thread Tools | |
| Display Modes | |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| changing operating limitations | pittss1c | Home Built | 46 | August 22nd 05 05:28 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
