Lycoming Carb Heat
Old September 15th 05, 12:20 AM
Bob Gardner wrote:
: I once read a report about carb heat use published by the NTSB (which, of
: course, I can't lay hands on now). In it, they pointed out the hazard of
: having disparate methods of carb heat use depending on engine and airframe,
: and suggested that full carb heat be applied any time the power was reduced
: below cruise power...no matter who made the engine or airframe. They felt
: that this standardization would have a positive effect on accident rates.
Perhaps, but I don't like to apply the carb heat unless I know it's needed.
In particular, there are situations where ice crystals would harmlessly flow through
the induction system. If carb heat (especially *partial* carb heat) is added, they
can melt enough to stick. Then you'd be stuck with an iced engine, below freezing,
and not enough heat to melt it.
Maybe I'm overly paranoid about it. I have had carb ice twice in Cherokees...
one with an O-320 in a long descent, and one in cruise (relatively low power in misty
weather at low altitude). Application was a non-issue once I saw the MP 2" below what
I set it. I'll agree that on an IMC missed or legitamate go-around the pucker factor
(and timing constraints) would be more of an issue.
I think that the Cessna left it in the POH from the O-300 Continental days as
a CYA when the switched to Lycoming. Never a good reason to change it, so left it was
it was required before.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old September 15th 05, 12:49 AM
Bob Gardner
This is what Lycoming says in its "Key Reprints from the Lycoming Flyer"....
Note the sentence "It is also appropriate....in the traffic pattern."
Bob
"In conditions where carburetor ice is likely to form, the pilot may use
heat during cruise to prevent the formation of ice in the carburetor. It is
also appropriate to use full carburetor heat, if needed, to prevent icing
when operating at low power for instrument approaches, or for flight in the
traffic pattern. Unless the aircraft is equipped with a carburetor air
temperature (CAT) gage, and very few general aviation aircraft are, use of
full carburetor heat is recommended. An unknown amount of partial heat can
actually cause induction ice in the float type carburetor. This may occur
when moisture in crystal form in the incoming air that would ordinarily pass
through the induction system without any problem is melted by the partial
heat. This moisture then freezes when it comes in contact with the cold
metal of the throttle plate."
of
airframe,
reduced
felt
rates.
needed.
flow through
added, they
freezing,
Cherokees...
power in misty
2" below what
pucker factor
as
left it was
-Cory
* Cory Papenfuss *
Old September 15th 05, 03:55 AM
Ash Wyllie
Mitty opined
Gents,
Though this is not strictly an IFR question, I am pretty sure that you have
opinions that I would like to get.
Subject is Lycoming O-360 engines. I have flown behind a number of them in
Pipers and the POH instruction on carb heat is always "as required."
Specifically there is no requirement for carb heat on the landing checklist.
This makes sense to me as the intake charge is routed through the oil pan cum
intake manifold and, with the throttle nearly closed hence low flow
velocity, should get adequately warmed up. At least that is my rationale
for why the POH does not call for heat.
I am about to get checked out in a Civil Air Patrol 172 that has an STC'd
O-360 installed in place of the original Lycoming O-320. The 172 POH wants
carb heat on approach. This makes no sense to me. If I have to do a go
around it is just one more workload item/one more thing to forget and, from
my Piper experience, it does not appear to be necessary. My guess, without
benefit of any actual facts, is that this POH requirement comes from
Cessna's Continental roots and has no engineering justification. So it
seems wise to ignore it.
Comments? (Please, let's not go to the FARS with this question. That is not
my interest.)
I flys a 172 with an O-360 engine and d not use carb heat on approach, I have
never had a problem, on approach.
The 2 times that I have had carb ice problems have been in cruise and high
humidity. Go figure.
-ash
Cthulhu in 2005!
Why wait for nature?
Old September 15th 05, 11:09 AM
David Cartwright
"Mitty" wrote in message
wants carb heat on approach. This makes no sense to me. If I have to do
a go around it is just one more workload item/one more thing to forget
and, from my Piper experience, it does not appear to be necessary. My
guess, without benefit of any actual facts, is that this POH requirement
comes from Cessna's Continental roots and has no engineering
justification. So it seems wise to ignore it.
I'm not familiar with the 172, but in the PA-28s I fly I was taught always
to have carb heat on when below 2,000rpm, which would certainly be the case
on an approach - so much so that checking/adjusting the carb heat setting is
now a ritual that I subconsciously carry out whenever changing the power
setting.
At 300 feet or so, though, you'd switch it to "cold", mainly to give you
maximum power in the event of a go-around, but also in the knowledge that
having the carb heat on means you're getting some unfiltered air into the
engine, and the air can be quite mucky at, or just above, ground level.
D.
Old September 15th 05, 11:13 AM
David Cartwright
"Bob Gardner" wrote in message
With regard to your transition into a Cessna model that I have not seen,
is the carb heat control still to the left of the throttle? Can it not be
pushed in with your thumb while the throttle is being pushed in by the
base of your palm?
On the PA-28 I fly the carb heat is (rather idiotically) immediately to the
right of the mixture control, which made my instructor sweat one day when I
was looking out of the window, and leaned over and pulled the wrong one.
Fortunately I noticed when the engine stuttered, before I'd leaned it off
completely, and a quick shove restored power!
D.
Old September 15th 05, 02:39 PM
Kai Glaesner
David,
Reminds me of one of my touch-and-goes in a (then new to me) Pa 28, when
I intended to pull the carb heat up to "cold", but instead pulled the
friction lock up...
Enriching the mixture and opening the throttle became impossible then
and in the aftermath I'm glad it was a touch-an-go and not a go-aroud... :-/
Best regards
Kai
Old September 15th 05, 07:11 PM
Dan Luke
"Roy Smith" wrote:
Your Piper experience differs from mine. Facing a long slow ILS through wet
clouds in a Piper, I'd set full carb heat, a minute or two before reducing
power. Ever taxi off the runway and have your engine quit?
I have had it quit on short final (in a PA-28-181). Almost exactly
the situation you described -- ILS on a cool day with very small
temp/dp spread, low vis, low scattered layer.
My CFII always used carb heat on a C-172 O-320 at anything less than full
power in wet conditions, and I've continued the practice with my 172RG O-360.
I have had one carb ice incident in 700 hours of operating an O-360, and that
was after a long taxi out on a wet morning. The engine would not throttle up
for the mag check, and half minute of carb heat cleared it.
Has using carb heat during damp approaches really kept me out of trouble? I
don't know; maybe it was my lucky key chain.
Dan
C-172RG at BFM
Old September 15th 05, 09:21 PM
Victor J. Osborne, Jr.
I too have had carb ice in the clouds, cold OAT. Noticed low power (full to
maintain alt.) Carb heat solved it. Never had a problem on final but then
I didn't have that many IA's in the cold/clouds.
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
"Roy Smith" wrote in message
temp/dp spread, low vis, low scattered layer. Over the airport
boundary, I pulled the throttle back to idle to land and things got
quiet. I was on the ground almost before I had a chance to realize
what went wrong. Hung out for a while on the runway while the ice
melted then started up and taxied off. Had a mechanic look at it, he
found no problems, so we assumed carb ice.
From that day on, I used carb heat in Pipers on instrument approaches.
I've also gotten carb ice in an Archer at cruise power in clouds.
Old September 16th 05, 11:51 AM
David Cartwright
"Kai Glaesner" wrote in message
om...
the right of the mixture control, which made my instructor sweat one day
when I was looking out of the window, and leaned over and pulled the
wrong one. Fortunately I noticed when the engine stuttered, before I'd
leaned it off completely, and a quick shove restored power!
Reminds me of one of my touch-and-goes in a (then new to me) Pa 28, when I
friction lock up...
It does make one wonder about "progress" in design. The PA-28 I mentioned
above is a late-1980s Warrior-II, and the carb heat is just to the right of
the mixture control (so you have to physically lean and reach past the
mixture control to get to the carb heat). The throttle friction is in the
vicinity too, thus making it susceptible to Kai's faux-pas.
Compare this with another PA-28 in our club which is 20 years older. The
throttle is a plunger-type, with the friction nut encasing the stem
(impossible to get wrong, albeit admittedly more fiddly than a lever), and
the carb heat is another plunger, placed sensibly next to the throttle (just
below and to the left, if memory serves) and a decent distance from the
mixture control.
Sadly, then, the designers of the later version made it easier to pull the
wrong thing, and more awkward to reach the carb heat. Oops.
D.
Old September 21st 05, 07:43 PM
Ron Natalie
paul kgyy wrote:
The key is the "as required". That puts the monkey on your back.
Lycomings do incur carb ice, though perhaps less often.
Tell me about it. I used to have a GO-435 lycoming. The engine
always ran hot and the conventional wisdom was that the PS-5C
pressure carb was near immune to carb ice. Well, we had it
happen. Margy flew back from the next field over at 20" of
MP (about ten minutes) and it wasn't that cold of a day even.
The thing iced up about the time we hit the pattern.
Of course, the replacment engien can't get carb ice (no carb).
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 02:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 06:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 08:26 PM
Carb heat specs? Rich S. Home Built 2 November 13th 04 05:39 PM
alternate carb heat Ray Toews Home Built 16 October 29th 04 01:41 PM
