Kid day at the airport...
Old September 16th 05, 11:05 PM
john smith
The FAA usually feels that they don't have to define commonly used English
words. Webster's or Oxford already does that job nicely.
Like trying to find their definitions for words like "densely populated"
and "sparsely populated" in the FAA's dictionary.
  #32
Old September 16th 05, 11:38 PM
Jay Honeck
If you had fewer clouds than the standard definition of "scattered" (which
isn't the FAA's definition), then perhaps you should have described them as
"few".
As I've stated, it was even fewer than "few"...
But in any case, I'd say what we're "getting hung up on" is your use of the
word "cloud". The number of clouds is irrelevant. If there's just one,
it's still illegal to touch that one cloud while operating VFR (the exact
distance depends on the particular airspace, but there's no allowance for
actually touching a cloud while VFR).
IMHO we need a better working definition of "cloud". Remaining "clear
of clouds" or "x distance from clouds" is all fine and dandy when
they're big, massive CBs -- anyone can figure that one out.
But what of these little puffies? Somehow treating a Toyota-sized puff
with the same deference as a 50-story cumulo-nimbus cloud seems absurd.
IMHO, if you cannot see through the condensed moisture suspended in the air,
it's a cloud. You may argue that it's so small as to not present a safety
issue, but the legal requirement does not provide exceptions for clouds that
are small enough to see around.
What is the source of that tid-bit, if you don't mind sharing? Or are
you just restating the "clear of clouds" line from the FAR-AIM?
(As a reminder: "legal" is not the same as "safe", just as "illegal is not
the same as "unsafe"...the two terms often coincide, but you need to meet
both "legal" AND "safe" as a pilot).
Right. I believe I was both, but it's all going to come down to the
FAA's definition of "cloud".
If you can see THROUGH, then you're just fine, IMHO. That's not a cloud,
it's a visibility reduction. If you cannot see through the cloud, you have
no business touching it, no matter how small.
If that's the FAA's definition of "cloud" I was clearly in violation of
the FARs. I personally don't think that's what is meant by "clear of
clouds" (or even "cloud", for that matter) -- but I can't find any hard
and fast definition of "cloud" in the FARs...
Crap. We could go down this road with other FAA weather descriptions,
too.
What's "fog"? I've flown in haze that was pretty close to fog, and
I've seen fog that wasn't as thick as the haze we routinely fly in
around here in August. Most people would say it's illegal to fly VFR
in fog, no?
What are "known icing conditions"? By some people's definition of the
FARs I fly in them all the time, VFR. Of course, I'm thousands of feet
below the freezing level, in light rain -- but technically I'm in
"known icing conditions" by some definitions...
Mary and I have pretty stringent minimums that we won't violate when
flying. At no time do we ever fly in any manner that we don't *both*
agree is "safe." We also both have a solid working knowledge of the
FARs, and we do not consider cloud, er, "Puffie Dancing" (that just
doesn't have the same 'ring' to it) to be in violation of the FARs.
Dipping a wing in a puffie on a clear VFR day, far from any airport,
hundreds of miles from the nearest busy airspace, is one of the true
joys of flying, and it would strike me as sad to think that someone
would view it as "illegal" or "unsafe"...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #33
Old September 16th 05, 11:42 PM
Jay Honeck
-- and they don't critique my landings!
...sorry about that. :-)
Montblack
Did you critique my landings?
Can you say "forward CG"???
ducking!
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #34
Old September 16th 05, 11:50 PM
Jim Burns
ROFL! Run Jay, he can't catch ya! or just stop and tell him a joke,
laughing will kill him!
"Jay Honeck" wrote in message
Montblack
ducking!
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #35
Old September 17th 05, 12:23 AM
Jay Honeck
Secondly, you certainly have not made clear that you have been
obeying the spirit of the FARs.
I know I shouldn't even bother to respond
(Feel...myself...being...paralyzed...by...the...co bra's...stare...),
but how so?
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #36
Old September 17th 05, 12:54 AM
Andrew Gideon
Jay Honeck wrote:
SomehowÂ*treatingÂ*aÂ*Toyota-sizedÂ*puff
Sure, but I'm not getting w/in 500' of a "50-story cumulo-nimbus cloud".
The legal clearances are a minimum; sanity sometimes dictates additional
spacing.
BTW, I've never seen a definition of "cloud" either. I'm not sure I'd use
the "see through" description. Although that does make sense, I think I'd
use a stricter definition: a region with less than VFR visibility.
That is, if there's a chunk of sky with visibility below 3 miles, I'd call
that a cloud.
I'm not sure exactly why that definition appeals to me, but it does.
Perhaps because it fits with other limitations on VFR flight.
- Andrew
  #37
Old September 17th 05, 12:59 AM
Peter Duniho
And as I've stated, it really doesn't matter what the number of clouds was.
But since you brought it up: "few" is any number of clouds from 0
(non-inclusive) to fewer than 1/8 sky coverage. The only "fewer than 'few'"
is no clouds at all.
Something wrong with your dictionary?
Remaining "clear
Why? The bottom line is this: if an airplane could fly through the cloud
without you seeing it until it has emerged, it's a safety hazard. Even the
"semi-truck" sized clouds you described are capable of creating that
situation.
air,
safety
that
My "source" is the dictionary, along with my opinion. I did write that it
was my opinion. However, it is based on sound, logical reasoning: "if you
cannot see through..." The point of the cloud clearance requirements is to
allow for "see and avoid". If you cannot see through the condensed
moisture, then it is preventing "see and avoid", and the requirements
intended to allow "see and avoid" should prevail.
What is YOUR justification for not counting as a cloud an area of condensed
moisture that blocks your view of possible air traffic?
As has been pointed out to you: if the FAA does not provide a definition,
you look to your dictionary.
have
There's a lot of things that the FARs don't define explicitly. However,
that doesn't mean each of us gets to make up our own definition for those
words.
too.
I doubt it. At the least, you didn't provide any examples of the above
statement.
in fog, no?
There are no aviation regulations governing flight in "fog". There ARE
regulations governing flight in particular visibility conditions, but you
are permitted to fly VFR in "fog" as long as your visibility is at least 1
mile (for Class G airspace and certain other situations...higher for other
kinds of airspace, of course).
You can define "fog" however you like. Since the word isn't used to
describe the rules pertaining to VFR flight, it doesn't matter what the
definition you use is.
By which definitions? The FAA says "known icing conditions" are visible
moisture with the outside air temperature at or below freezing. By whose
definition would you be in "known icing conditions" when flying "thousands
of feet below the freezing level"?
The FAA's definition is pretty clear. People can and do violate it. But
that doesn't change the specificity of the FAA's definition.
flying.
Apparently they are your own, however. The FAA uses different minimums.
agree is "safe."
As stated befo "legal" and "safe" are not necessarily the same thing.
You can be "safe", and yet still "not legal".
FARs,
So you say.
However, it is.
Replace the activity with any number of other statements: "touching a float
down, on a smooth glassy lake"; "rolling inverted, below a pure blue sky and
above rolling green hills"; "soaring with the condors over the vast desert
in an unpowered glider". They all could be called "one of the true joys of
flying". Yet, they are not legal for all pilots at all times.
Just because something is enjoyable, or even may be "one of the true joys of
flying", does not mean that everyone has the unrestrained privilege to
engage in that activity whenever they like.
Your activity is, at a minimum, illegal. It may well be unsafe as well, at
least in the sense that you have abandoned the cloud clearance requirements
of the FARs, allowing for the potential of other air traffic emerging from a
cloud right where you are.
I will certainly grant that, for small enough clouds, spaced far enough
apart, making some basic assumptions about the slowest air traffic likely to
be flying in your area, you can make an assertion that because you have been
monitoring the airspace prior to your approach to the cloud, and because
that airspace has been clear of traffic, you know no air traffic could have
entered the cloud at a time that would result it leaving the cloud just as
you were adjacent to the cloud.
But none of that makes it legal, and in fact it assumes you have perfect
knowledge of the air traffic in the area, and have not overlooked someone
flying through the area.
As I like to point out to people who roll through stop signs, park on the
wrong side of the street, etc.: practically no one drives their vehicle into
an obstacle that they saw, and yet lots of collisions still occur. The
reason we follow certain rules and regulations is that we sometimes do not
see the obstacle, and following those rules and regulations either keeps us
safely away from the obstacle, or allows us for more room for error, to
avoid the obstacle.
Pete
  #38
Old September 17th 05, 01:01 AM
Peter Duniho
but how so?
What do you mean "how so?" The FARs state you must remain clear of clouds
(at a minimum) while flying VFR. Nothing you've written has explained how
it is you managed to put your wing in a cloud, while still remaining clear
of the cloud.
There's an *absence* of that information. I can't explain it other than to
reiterate the absence of that information.
Pete
  #39
Old September 17th 05, 01:08 AM
John Theune
"few".
too.
in fog, no?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Jay;
I don't think you and Mary agreeing that something is safe gets to
override the FARs. It pretty clear that the FARs say no touching the
clouds when your VFR. You can do it if you choose, but don't delude
yourself into thinking that it's legal. I drive over the speed limit
but I know I'm breaking the rules. It does not stop me from speeding
but I know that I may hve to pay the price and I accept it.
John
PS. I would not brag about it on the net if I were you. Speeding they
have to catch me doing but the FAA operates by a differnet set of rules.
  #40
Old September 17th 05, 01:10 AM
Flyingmonk
Good job on sharing the experience with the kids. Stay safe.
Bryan "The Monk" Chaisone
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Palo Alto airport, potential long-term problems... [email protected] Piloting 7 June 7th 05 12:32 AM
WI airport closure Mike Spera Owning 0 March 9th 05 02:53 PM
N94 Airport may expand into mobile home community, locals supportive William Summers Piloting 0 March 18th 04 04:03 AM
Rules on what can be in a hangar Brett Justus Owning 13 February 27th 04 06:35 PM
