Aerodynamic Drag
Old September 24th 05, 06:03 AM
Mike Rapoport
Eanest:
How about a related question? On my Helio Courier the fusilage/wing
intersection is slightly less than 90deg. The intersection looks like an
aerodynamic disaster. How much drag would be eliminated with a fairing than
can only come down the fusilage three inches? How about a two part fairing
(one part would be on the door) that could come down 6 inches?
Mike
"Ernest Christley" wrote in message
om...
Kyle Boatright wrote:
Help me figure out how much speed my RV can gain by fairing the Pitot
Tube.
The pitot is made of 3/8" OD aluminium tube, with a 6" length
perpendicular to the airstream. That gives a surface area of 3/8" x 6" =
2 1/4 sq inches. My understanding is that the Cd of a cylinder is .5 and
the Cd of a faired shape can be as low as 0.005, but let's assume 0.05
for the faired shape.
The effective area is .5 x 2 1/4 square inches = 1.125 square inches for
the cylinder.
and
0.05 x 2 1/4 = 0.1125 square inches for the streamlined shape.
The difference is 1.125-.1125 = 1.06875 square inches. Let's call it 1
square inch...
Assuming I'm in the ballpark so far, how much power can I "save" at 175
mph by streamlining the pitot, which eliminates essentially 1 square inch
from the aircraft's effective frontal area?
KB
Kyle, any answer you get will be further complicated by the modifications
in intersection drag. But ignoring that...
From http://142.26.194.131/aerodynamics1/Drag/Page4.html , the equation
for parasitic drag is:
Dp = CDp x S x ½ r V^2
Essentially, once you remove the drag of the unfair pitot tube, and then
accellerate, Dp will come out the same. You're using the all the horses
the engine has to make the plane go faster, vs dragging a pitot tube
around. So:
CDp x S1 x ½ r V1^2 = Dp = CDp x S2 x ½ r V2^2
I only marked S and V with ones and two's, because everything else will
drop out of the equation (making a BIG and unlikely assumption that the
drag coefficient doesn't change), leaving:
S1xV1^2 = S2xV2^2
But the useful form of this for your purposes is:
V2^2 = S1 x V1^2 / S2
Now, your fairing the pitot is only one part of the entire airplane, and
the entire airplance has to be considered to determine the increase in
speed. I have no clue what the surface area of an RV of any sort is (but
a Delta is 183ft^2 8*) Assuming your RV has the surface area of a C-172,
174ft^2, you've just dropped 0.007ft^2. Plugging the numbers:
V2^2 = 174 x 175^2 / 173.993
V2^2 = 30,626
V2 = 175.00352
Are we ready for Reno yet 8*) You'd probably double this increase by
cleaning up the intersection drag. If the tube is located in a position
that will cause it to produce rough air for everything behind it, there
would also be some (insignificant) benefit to be gained there.
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 09:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 01:18 AM
Forward CG Experience Jay Honeck Piloting 41 November 19th 03 03:54 PM
Did we decide if ballasted pullups are higher???????? Lars Peder Hansen Soaring 22 October 8th 03 01:45 AM
