#11
sfb wrote:
political boondoggle as it costs more BTUs to manufacture than it provides. Oh. I didn't know that. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Why is the Federal government subsiding ethanol manufacturing? If it was
such a good flipping deal, why haven't the energy companies gone into the ethanol business. Ethanol is good for the corn crowers which last I looked was not the county in general. There are serious studies that demonstrate ethanol is an energy loser as it requires more BTUs to manufacture that it provides. Ethanol is the prime example of the agriculture lobby taking advantage of the energy panic to have the taxpayers subsidize their over capacity. Factory automation has eliminated many more jobs than have been shipped overseas. If the country chooses not to use public money to keep unprofitable factories open, why must it subside unprofitable agriculture? "Jay Masino" wrote in message ... Despite the fact that mandating ethanol blends would be bad for you, it's really better for the country in general. Using ethanol, along with biodiesel, can go along way towards making our country less dependant on foreign oil. I'm torn. I want some sort of alternate fuel to be developed for my airplane, but it would also be great to tell the middle east to kiss our ass. Presently, the autogas STC for my 160hp Cherokee is fairly expensive (~$1500 last time I checked), and it requires you to use premium unleaded, so the cost savings isn't quite as much. I haven't been able to verify whether Maryland requires an ethanol blend, but I think it does, so even if I went back to 150hp pistons, I'd still be screwed. Anyway, using ethanol and biodiesel is a great idea. I've even considered trading my commuter car for some model of VW diesel so that I can burn biodiesel. I think that increasing the percentage of ethanol to as high as a normal car can stand, is also a good idea. Sounds like Rep. Nussie isn't that crazy. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Go to the airport and count the airplanes. Now go flying and count the corn
fields. Its politics, sad but true. If it really made sense to use ethanol in gasoline (because it was cheaper/better) there wouldn't need to be any mandates or subsidies. Mike MU-2 "Jay Honeck" wrote in message news:b3c_e.369489$x96.190155@attbi_s72... Today Rep. Jim Nussle -- potentially the future governor of Iowa -- was reported as proposing that all gasoline sold in Iowa be required to contain 20% ethanol additive. Presumably, this legislation, if passed, would make the sale of regular unleaded gasoline illegal in Iowa. See the story he http://press-citizen.com/apps/pbcs.d...509270309/1079 As those involved in grass-roots aviation know, this would be another nail in the coffin of General Aviation in Iowa. Without the availability of regular unleaded gasoline -- a fuel that many have seen as the savior of General Aviation, since the discontinuation of 80 octane aviation fuel production -- many would be forced to run 100 octane aviation fuel, because ethanol-based fuels are not approved for use in aircraft engines. This would be a disaster for many of us. Small carbureted aircraft engines were quite simply never designed to run on 100 octane aviation fuel, which contains far more lead than our engines need, costs 30% to 50% more than regular unleaded fuel, and causes engine problems for many of us. Personally, I have run over 6,000 gallons of regular unleaded gasoline through our airplane, at an average savings of over $1.00 per gallon. I know dozens of aircraft owners who have done the same -- and I also know that, for many, losing that savings would be the difference between flying and not flying. This legislation, if passed, would ground those pilots, and would effectively put general aviation beyond the means of many current pilots in Iowa. Below is a letter I have sent to Rep. Nussle. I urge everyone to send similar letters to Mr. Nussle, as I don't believe he is aware of the potentially GA-crippling side-effect of his proposed legislation. Contact him he http://nussle.house.gov/contact.htm Thanks for your help -- and blue skies! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Dear Rep. Nussle, Your recent call for mandating that all gasoline sold in Iowa contain ethanol. I understand your position, but there is a negative aspect about your proposal that you may not be aware of: It could kill grass-roots General Aviation in the state. How? Most small airplanes (Pipers, Cessnas, etc.) have carburetors, and were designed to run on 80 octane aviation fuel. Since 1999 (or so), this fuel has been unavailable. The oil companies simply stopped making it. After that, we were forced to start using 100 aviation gas. Unfortunately, this fuel has 14 times more lead in it than our engines were designed to run on. As a result, our engines ran rough and spark plugs were badly fouled. This was a dangerous situation, to say the least. Luckily, the EAA (Experimental Aircraft Association, based in Oshkosh, WI) stepped up to the plate, and was able (after extensive testing) to get regular unleaded auto gas approved for use in our planes. No more rough running engines, no more fouled spark plugs -- and it was MUCH less expensive to run. In fact, usually the savings ran to over $1 per gallon! (When you're burning 15 gallons per hour, this is significant.) Unfortunately, the EAA was NOT able to get the use of ethanol approved in our aircraft engines. This means that we can ONLY run "pure" unleaded gas. Use of any ethanol additives is specifically prohibited by the FAA. Thus, as you can see, if you make regular unleaded gasoline unavailable in Iowa, you will make it impossible for many of us to fly our small airplanes -- surely an unintended side effect of your otherwise worthy idea! Please continue to sponsor legislation that makes ethanol- gasoline cheaper than regular unleaded gasoline. This, in my opinion, is the very best way to get EVERYONE to use ethanol. Mandating that regular unleaded be illegal is simply not the way to do business in Iowa, and I hope I've given you one good reason why this is true. Sincerely, Jay Honeck Owner/Innkeeper The Alexis Park Inn & Suites Iowa City, IA |
What are car gas pilots in MN,
MT, HI doing? In Minnesota there is a small distribution system at present for non-alcohol fuels to make them available at airports and marinas, as well as a few gas stations. In a few years we are mandated to go to 20% ethanol but I don't know if that system will be continued or not. |
"And I don't see anyone
flying less." I don't see anyone flying period. Living in the Twin Cities, 9-11 seems to have taken such a big bite out of General Aviation that I rarely hear single engine aircraft on nice Saturdays anymore. I'm really scared of the future of GA as my airport (SSQ) is only populated with old timers. Paying $170 for a damn gascolator bail of a Cherokee (this was on another thread) makes it awfully hard to be enthusiastic and attract new people to aviation. |
sfb wrote:
Ethanol is the ultimate political boondoggle as it costs more BTUs to manufacture than it provides. But you don't have to use petroleum to provide those BTUs; consequently, it does reduce dependence on foreign oil, and it does pollute less than petrol. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
sfb wrote:
There are serious studies that demonstrate ethanol is an energy loser as it requires more BTUs to manufacture that it provides. But that energy doesn't have to be produced by burning oil. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
"Jonathan Goodish" wrote in message ... In article , (Jay Masino) wrote: Despite the fact that mandating ethanol blends would be bad for you, it's really better for the country in general. Using ethanol, along with biodiesel, can go along way towards making our country less dependant on foreign oil. I'm torn. I want some sort of alternate fuel to be Our "dependence" on foreign oil is a problem of our own creation--not because of our consumption, but rather because of legislation and regulation that restricts supply. The United States is presently the third-largest producer of crude oil in the world, ahead of every OPEC member except for Saudi Arabia. We could easily be the largest oil producer if the oil reserves under federal land were permitted to be explored. JKG The above isn't really true. There are not that many places off limits to petroleum exploration in the US and none of them have enough reserves to offset imported oil. Every availible drilling rig is drilling and has been for years. The new higher prices are also allowing production of petroleum that was previously uneconomic (like tar sands). The reality is that, until recently, only a small (~20%) percentage of the worlds population used any meaningful amount of energy and now perhaps 60% is using a meaningful amount of energy. That is a tripling in the number of consumers and the effects are obvious. Personally, I like the strategy of using Middle East oil until it is gone. The percentage of water produced by Saudi oil fields goes up every year...in a decade or two, three at the most, we won't care much about the Middle East. Mike MU-2 |
You're correct, but that doesn't negate the fact that there's only a certain amount of oil in the ground, and it's not gonna last forever. It's hard to argue with the concept of growing some corn or soybeans and making fuel from it. Even if it's not the complete answer, it still starts the ball rolling towards weening ourselves from fossile fuels. Jonathan Goodish wrote: Our "dependence" on foreign oil is a problem of our own creation--not because of our consumption, but rather because of legislation and regulation that restricts supply. The United States is presently the third-largest producer of crude oil in the world, ahead of every OPEC member except for Saudi Arabia. We could easily be the largest oil producer if the oil reserves under federal land were permitted to be explored. Crude oil is one problem, refining capacity is another. We do not have adequate refining capacity to meet domestic demand. Again, the lack of refining capacity is the result of legislation and regulation which makes it prohibitively expensive to build and operate refineries. Requirements for certain "blends" for certain domestic markets makes it more expensive and difficult to meet unexpected demand. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
| Thread Tools | |
| Display Modes | |
| Ethanol Powered Airplane Certified In Brazil | Victor | Owning | 4 | March 30th 05 10:10 PM |
| Sugar-powered plane unveiled | Mal | Soaring | 12 | October 26th 04 08:49 AM |
| Local Amoco now blending ethanol | Ben Smith | Owning | 5 | April 1st 04 05:37 PM |
