OK. I'm laughing out loud at that one. Well done.
Paul Remde "bumper" wrote in message ... By now, most will realize that electricity is pretty dangerous stuff and not to be trifled with. Yeah, it's maybe okay in small doses, flashlight batteries come to mind as being pretty safe if not swallowed. Not a believer? If you want to see the incredible destructive power that lurks in seemingly innocent, but higher voltage batteries, try touching the terminals on a cute little 9 volt battery to a scrap of fine steel wool!! (use caution and make sure the steel wool in on a surface that won't burn) Yup, 12 volts DC is right at the maximum sane voltage. Any more is downright foolish. In fact, the force fields that result from adding just 2 additional volts (14 volts DC) will cause the hapless pilot to undergo some sort of cultish brain damage. In some cases these poor deranged pilots will then start preaching on street corners, warning those who use lesser voltages that the end is near and they will be discharged. Curiously, by abandoning the idea of using DC (direct current), and switching all systems over to AC, alternating current, one can safely increase voltage doses up to about 120 VAC or so, with little attendent risk of dain bramage. Beyond that, there is the ever present risk of vaporization. Which is, of course, why pilots should do their best to avoid high voltage transmission lines. all the best, bumper (12 volts DC and proud of it) |
| Thread Tools | |
| Display Modes | |
| Battery Question | [email protected] | Soaring | 19 | September 15th 05 02:38 AM |
| Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 05:30 PM |
| 14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 02:37 AM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
| Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 10:12 PM |
