Why are non precision approaches not lined up?
Old October 6th 05, 07:42 PM
Greg Farris
Default Why are non precision approaches not lined up?
The title just about says it - I've always wondered WHY many
non-precision approaches (not talking about LOC only here, but VOR,
VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes it
looks as though the approach desginers have gone out of their way to
make sure the non-precision approach is just a few degrees off - as if
to say - "look stupid - this is not a precision approach . . ." But if
this were so, then we would have to wonder why SOME of these approaches
ARE lined up and straight-in. I'm surev there's a simple explanation
that will be pointed out here.
thanks,
G Faris
Old October 6th 05, 07:48 PM
paul kgyy
Many VORs are used for approaches to multiple airports (CGT for
example) - it would be a bit much to expect that every one will line up
perfectly. I'm surprised at how close they usually are.
Old October 6th 05, 08:10 PM
Steven P. McNicoll
"Greg Farris" wrote in message
Because the navaid is not on the extended runway centerline.
Old October 6th 05, 09:07 PM
Brad Zeigler
thanks,
G Faris
There are numerous reasons. Off field navaids often serve serveral roles in
both the enroute and approach environment for several airports. On field
navaids may not be straight in as the approach coarse must lead to the
runway, and unless the navaid is at the end of a runway, the course would
either be parallel to the extended centerline of the runway, or offset to
intersect with the runway or runway threshold. Finally, obstructions along
the approach path or missed approach may be a fact in offsetting the
approach course. Lastly, air traffic considerations may be a factor,
especially with smaller airports situated close to busy airports.
Old October 6th 05, 09:13 PM
Mark Hansen
thanks,
G Faris
I can think of a couple reasons. First, as other have said, the VOR
will not always be lined-up with the runway.
Secondly, it may be that the approach path has to come in at an
angle to avoid something, like high terrain, housing communities,
etc. (so they may have placed the VOR off center to facilitate
that).
Also, you shouldn't think of the difference between precision and
non-precision approaches as being lined-up or not with the runway.
Precision approaches are those that provide vertical guidance. Non-
precision approaches do not. That's the difference.
The fact that the typical precision approach uses a localizer which
is lined up with the runway (because the antenna is situated at the
field) does not make the approach 'precision' - the fact that it
provides vertical guidance does.
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old October 6th 05, 09:16 PM
John R. Copeland
"Steven P. McNicoll" wrote in message =
ink.net...
=20
"Greg Farris" wrote in message=20
VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes =
it
make sure the non-precision approach is just a few degrees off - as =
if
to say - "look stupid - this is not a precision approach . . ." But =
if
this were so, then we would have to wonder why SOME of these =
approaches
=20
Because the navaid is not on the extended runway centerline.=20
=20
Furthermore, those alignments usually are not to the airport reference =
point,
but instead cross that centerline somewhere near the approach end of the =
runway,
just far enough out to turn and land if the runway environment comes =
into view.
GPS/WAAS VNAV approaches and runway length Nathan Young Instrument Flight Rules 8 October 25th 04 07:16 PM
Closest SDF, LDA and LOC-BC Approaches Andrew Sarangan Instrument Flight Rules 17 June 5th 04 04:06 PM
The new Instrument Rating PTS C J Campbell Instrument Flight Rules 7 May 27th 04 01:35 AM
FS2004 approaches, ATC etc henri Arsenault Simulators 14 September 27th 03 01:48 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 02:43 PM
