#21
"Greg Farris" wrote in message =
... =20 OK - the VOR is not exactly on the runway centerline - maybe two = runway=20 widths off. Is that the reason then? Are we sure, or just guessing?=20 =20 G Faris We are not guessing. |
Steven P. McNicoll wrote:
"Matt Whiting" wrote in message news
No, the VOR is not on the runway centerline. It is several hundred feet off to the side of the runway. Why they didn't use the runway heading for this approach I don't know, but it could be for noise abatement, obstruction clearance, or other reasons. If they did that the MAP would be several hundred feet off to the side of the runway. True, but the MDA at ITH is something like 700' so you'd still be a long way from the runway when you broke out. I doubt that a couple of hundred feet of offset would be a big deal. That may be the reason, but I'm guessing there are other factors in play as well. Matt |
On Thu, 06 Oct 2005 19:42:18 +0200, Greg Farris
wrote: The title just about says it - I've always wondered WHY many non-precision approaches (not talking about LOC only here, but VOR, VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes it looks as though the approach desginers have gone out of their way to make sure the non-precision approach is just a few degrees off - as if to say - "look stupid - this is not a precision approach . . ." But if this were so, then we would have to wonder why SOME of these approaches ARE lined up and straight-in. I'm surev there's a simple explanation that will be pointed out here. Off-field VOR's are often used. If the runway is 09/27, and the VOR is North of the airport - you have no choice but to make it a circling approach. Obstacle or terrain clearance. |
Greg Farris wrote:
The title just about says it - I've always wondered WHY many non-precision approaches (not talking about LOC only here, but VOR, VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes it looks as though the approach desginers have gone out of their way to make sure the non-precision approach is just a few degrees off - as if to say - "look stupid - this is not a precision approach . . ." But if this were so, then we would have to wonder why SOME of these approaches ARE lined up and straight-in. I'm surev there's a simple explanation that will be pointed out here. thanks, G Faris Alignment is not what defines precision vs nonprecision; vertical guidance is the defining difference. As for alignment, the only way to get an "on-airport" NAVAID to provide a course right down the runway centerline is to place the NAVAID right on the centerline of the runway, but then that would be a hazard to airplanes as they had to swerve to avoid it as they were rolling out. Seriously, though, the reason the course is not lined up is that the TERPS criteria requires that it be aligned so as to cross the extended runway centerline at a point optimally 3000' from the threshold. There is some flexibility in this, as it can be aligned to cross the centerline anywhere from over the threshold itself, out to 5200 ft from the threshold, and in some cases can be aligned so it doesn't even cross the threshold as long as it's within 500' of the centerline at the 3000' point. Most on field NAVAIDS are a minimum of 500 ft from the runway centerline. The further the NAVAID is from the edge of the runway, the greater the difference between the course and the runway alignment. If the procedure had the same course as the runway, then it would parallel the centerline all the way down final, requiring an "S" turn rather than one gentle turn to lign up. At KITH, there's also a difference of 2 degrees between the airport magnetic variation (12W) and the ITH VOR/DME magnetic variation (10W), so even if the courses were parallel, the displayed headings would be 2 degrees apart. JPH |
#28
The feds build VORs and place NDB antennas in locations where they can get
the land at a decent price and where the terrain is suitable. The feds build runways for much the same reasons, plus allowing for terrain/obstacle clearance. It's asking a lot to expect everything to fall nicely into place. Bob Gardner "Greg Farris" wrote in message ... The title just about says it - I've always wondered WHY many non-precision approaches (not talking about LOC only here, but VOR, VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes it looks as though the approach desginers have gone out of their way to make sure the non-precision approach is just a few degrees off - as if to say - "look stupid - this is not a precision approach . . ." But if this were so, then we would have to wonder why SOME of these approaches ARE lined up and straight-in. I'm surev there's a simple explanation that will be pointed out here. thanks, G Faris |
#29
Sure are a lot of micrometers measuring something that is cut with a
chainsaw. If you consider the maximum allowable error that is allowed for VOR receivers and then plot that allowable error plus some safety factor you would most likely see an obstacle that the approach designer has to consider. It is even worse for NDBs. Paul "Greg Farris" wrote in message ... In article . net, says... Because the navaid is not on the extended runway centerline. Nope - Look at the VOR 14 approach to ITH (Ithaca New York - Just grabbed the book and picked that one by chance). The VOR is on the centerline, the runwya heading is 144.6° and the VOR approach is 133°. When you break out, you have to turn 11.6° right to land. I don't see why they couldn't have published it right on the 145° radial. GF |
#30
Greg Farris wrote: OK - the VOR is not exactly on the runway centerline - maybe two runway widths off. Is that the reason then? Are we sure, or just guessing? Is it better to break out with two runway widths of sidestep, or with the MAP "on" the extended centerline, but the runway visible out the side window? My question is why it's done that way. If we're sure that the answer is "to place the MAP on the centerline, regardless of heading" then that answers my question. You're arguing with the criteria. The criteria requires that the final approach course intercept the runway centerline, extended, at 3,000 feet from the approach end of the runway. There is a slight parallel option when that is not possible. If you want to learn all about it, check the TERPs criteria, which is available on Summit Aviation's Aviation Reference Library CD-ROM. |
| Thread Tools | |
| Display Modes | |
| GPS/WAAS VNAV approaches and runway length | Nathan Young | Instrument Flight Rules | 8 | October 25th 04 07:16 PM |
| Closest SDF, LDA and LOC-BC Approaches | Andrew Sarangan | Instrument Flight Rules | 17 | June 5th 04 04:06 PM |
| The new Instrument Rating PTS | C J Campbell | Instrument Flight Rules | 7 | May 27th 04 01:35 AM |
| FS2004 approaches, ATC etc | henri Arsenault | Simulators | 14 | September 27th 03 01:48 PM |
| Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 02:43 PM |
