Why are non precision approaches not lined up?
Old October 9th 05, 03:32 PM
Greg Farris wrote:
OK - the VOR is not exactly on the runway centerline - maybe two runway
widths off. Is that the reason then? Are we sure, or just guessing?
Is it better to break out with two runway widths of sidestep, or with the MAP
"on" the extended centerline, but the runway visible out the side window?
My question is why it's done that way. If we're sure that the answer is "to
place the MAP on the centerline, regardless of heading" then that answers my
question.
You're arguing with the criteria. The criteria requires that the final approach
course intercept the runway centerline, extended, at 3,000 feet from the approach
end of the runway. There is a slight parallel option when that is not possible.
If you want to learn all about it, check the TERPs criteria, which is available
on Summit Aviation's Aviation Reference Library CD-ROM.
GPS/WAAS VNAV approaches and runway length Nathan Young Instrument Flight Rules 8 October 25th 04 07:16 PM
Closest SDF, LDA and LOC-BC Approaches Andrew Sarangan Instrument Flight Rules 17 June 5th 04 04:06 PM
The new Instrument Rating PTS C J Campbell Instrument Flight Rules 7 May 27th 04 01:35 AM
FS2004 approaches, ATC etc henri Arsenault Simulators 14 September 27th 03 01:48 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 02:43 PM
