ELT location for V2C
Old October 11th 05, 05:13 PM
01-- Zero One
Ted,
I hope I did not mislead you. I fly an LS-3a, not a V2C. I was
responding generally about the dangers of flying projectiles in the
cockpit.
I mounted it ..er.. uh.. . I mean, it was mounted by the A&P by
screwing the retaining plate and straps to the baggage compartment tray
with a backing plate below the tray for strength. In the LS-3a, there
was just enough room to get it in next to the glider batteries.
Larry
"Ted Wagner" wrote in message
news:1128998777.1f71e5987c5709d715a54423cda1bf20@ teranews:
Larry, how did you mount it? I mean, how specifically is it attached to
the fuse?
"01-- Zero One" wrote in message
Hmmm?? In front of the wing spar sounds to me like you now have a nice
forward moving projectile in the event of a forward moving collision.
I also have one of these units and I had it installed behind the spar
because 1) that was where I could fit it in and 2) there was a natural
barrier (the spar) to keep it from hitting me in a sudden stop.
Larry
"Armando Pucci" wrote in message
Dear ~ted/2NO
On mine V2cM the ACK ELT was originally installed by factory on the
left
side of baggage compartment just BEFORE of
the wing spars using original ACK support with a quick release latch;
The
remote control is installed on the panel.
Sds VoLo.
Armando R. Pucci
Ventus 2cM (AR)
P-3 location lists Marco P.J. Borst Naval Aviation 5 January 2nd 05 04:52 PM
P-3 Orion Aircraft Location Reports - updated Marco P.J. Borst Naval Aviation 0 October 24th 04 03:49 PM
FS2004/FS9, Set location to non-airport? Squirrel Instrument Flight Rules 8 September 24th 04 01:43 AM
mysterious helipad location (Dallas, TX) Kyler Laird General Aviation 5 February 20th 04 04:57 PM
lookup navaid location Dan Jacobson General Aviation 3 November 21st 03 10:35 PM
