Flying Thru Congested Areas
  #29
Old January 8th 04, 07:56 PM
Jeff
I dont know why garmin couldnt make something like that possible, there is an
empty slot in the 430 for future options.
"O. Sami Saydjari" wrote:
Jeff,
I have already been playing with the 430 simulator to get familiar with
the controls. I never thought of using it for flight planning. Neat
idea! Would would be even cooler is if you could plan your trip on the
simulator, write to one of those small memory sticks, and then stick the
stick intot he Garmin 430 and have it download your plan. Perhaps, the
next generation will do that too.
-Sami
Jeff wrote:
Sami
what you can do for long flights is if you dont have it, and since your
getting the 430 anyways you may want it, go to
http://www.garmin.com/products/gns430/
and download the simulator for the 430
you can put in your route direct, see how it looks and amend it from there
then put it in duats for wind, time and fuel consumption.
Its a good program to have and mess with so you can get familiar with the
430 anyways.
I have a garmin handheld 295, I do my route on it, then put it in duats,
then when I get to my plane I put the route from the 295 into my 430.
To get great circle routing which is easy to put on a chart
out of DUATS, select the "direct routing for GPS/Loran".
Must have missed this option. Thanks.
I recommend purchasing a "low altitude enroute planning chart"
(or something like that) from your favorite chart shop.
Great idea.
In truth, for longer trips, we file VOR routing (not necessarily
airways) more and more often, because with judicious use of
direct segments it usually adds very little (maybe 1%) to the
trip and makes filing flight plans easier.
It makes filing flight plans easier than what? vivtor airway routes?
Seems a direct file is the easiest. I assume I can just file my route
as "KISW direct KHEF" (Wisconsin Rapids, WI to Manassas, VA).
Marske Flying Wing discussion Group mat Redsell Home Built 0 September 19th 04 02:58 PM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Flying Wing Design workshop in july 04 mat Redsell Home Built 1 May 5th 04 02:53 PM
Flying Magazine's Instrument Flying 1973 Steven P. McNicoll Instrument Flight Rules 16 January 12th 04 04:50 PM
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan David Megginson Instrument Flight Rules 0 July 9th 03 04:04 PM
