Oil Pressure Gauge Troubleshooting
Old October 19th 05, 04:04 AM
Cy Galley
Default Oil Pressure Gauge Troubleshooting
Remove the hose and see if you can look thru it.
"Kyle Boatright" wrote in message
"Cy Galley" wrote in message
news:lFh5f.442882$x96.137443@attbi_s72...
Is the hose clear? Sounds almost like you have a check valve in the line.
Did you make up the hose by putting on ends? If you made the hose or had
it made to length, there is a possibility that a "donut" has been cut
out of the hose side wall making a flapper valve. Happens when someone
doesn't use a mandrel.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
The hose was from a mail-order racing parts supplier (Summit Racing,
IIRC).. It is one of their stock lengths. No idea if they use mandrels or
not.
KB
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
Vaccuum Pressure Gauge Al Owning 4 January 16th 04 05:26 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
