#11
Kyle Boatright wrote:
"Jim Logajan" wrote in message .. . "Skylune" wrote: Statistically, GA is the most dangerous of all forms of transportation. There is no (reasonable) debate on this point. Reasonable debate!? You obviously haven't seen _any_ debate, reasonable or otherwise, to spout such sweeping and easily refuted nonsense. According to cross modal studies in the U.S.[1] _and_ Australia[2], motorcycling is, by distance traveled measures, more dangerous than GA: In the U.S. in 2000, according to reference 1, there were ~27 fatalities per 100 million vehicle miles for motorcyclists. In that same year there were ~2 fatalities per 100,000 hours flown for GA. Assuming a modest average airspeed of ~100 mph and only 1 person in each aircraft, that works out to ~20 fatalities per 100 million vehicle miles for aircraft. In Australia in 1999, one study (table 3 in reference 2) showed there were ~17.5 fatalities per 100 million vehicle kilometers for motorcyclists. In that same year there were ~8.5 fatalities per 100 million vehicle kilometers for aircraft. In fact the Australian study shows motorcycling to be more hazardous than GA by several common measures. What is fascinating about the Australian study are some of the normalized numbers in Appendix A showing that even bicyclists and pedestrians are are greater risk by some measures than GA flyers: Table 5: Fatalities/100,000 vehicle hours travelled ------------------------------------------ Bicyclists 5.27 General Aviation (fixed wing) 5.15 Fatalities/100 million passenger kilometres ------------------------------------------ Pedestrians 15.36 General Aviation (fixed wing) 6.22 Is it safe? Depends on your risk threshold. If you are willing to risk walking across a road, you should have no qualms about taking a general aviation flight. [1] "Fatality Rates for Selected Modes" http://www.bts.gov/publications/tran...re_01_145.html [2] "Cross Modal Safety Comparisons" http://www.atsb.gov.au/aviation/rese...ross_modal.cfm If you eliminate the *stupid* fatalities in GA, my guess is the risk goes down by 1/2. Stupid includes VFR into IMC, Fuel Starvation, and low altitude maneuvering. Stupid pilots are their own worst enemies and flying is notoriously unforgiving of stupidity. KB But if you remove the those classes of accidents from flying then you need to make the same changes to the other modes of travel and I think you find that just removing the achohol related accidents from driving brings the numbers down more then they will for flying poorly since the % of achohol related airplane accidents is much lower then for cars/bikes |
"John T" wrote in
m: "Kyle Boatright" wrote in message If you eliminate the *stupid* fatalities in GA, my guess is the risk goes down by 1/2. Stupid includes VFR into IMC, Fuel Starvation, and low altitude maneuvering. Stupid pilots are their own worst enemies and flying is notoriously unforgiving of stupidity. While I generally agree with your statement, I take slight issue with "VFR into IMC" being the result of stupidity. I might support stupidity as the cause of "*continued* VFR into IMC", but even that is iffy. As support for my argument, I offer night flight. It is very easy to penetrate a cloud on a moonless night - especially if there is a high overcast. I'd agree a pilot in this condition should try to extricate themselves as expiditiously as safety allows, I wouldn't necessarily chalk up the scenario to "pilot stupidity". I would't mind seeing adjusted statistics eliminating night flight from the equation as well. I don't put night flight in the "stupid" catagory, but it certainly has risks that "day VFR" fights do not. -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
"Paul Stuart" wrote in
ups.com: Jim Thanks for the interesting statistics that compare GA favorably to other "recreational" type modes of transport. I'd be interested to see a comparison with horse riding, which I suspect has actually got a pretty bad accident rate, although not many people would think of it that way. And, although I've not been posting to this group long, I've learned enouigh already to observe that you have no hope of elucidating any kind of "reasonable debate" from Skylune. HA! ANYONE who reffers to themselves in the third person should go directly to the kill file.... -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
Idiot. Your nonsense is "easily refuted."
In fact, the graph you attached from BTS compares apples and oranges. I suggest a Stat 101 course from your local community college. Studies that adjust usage rates using the same denominator (i.e. passenger miles, hours travelled, etc.) all conclude that GA is the most dangerous form of transportation. Here is one example: http://www.planecrashinfo.com/cause.htm Also, you may want to check the BLS studies of most dangerous occupations, which can also serve as a proxy. Aircraft associated professions have the highest mortality rates in the US, behind only lumbering. Or, the common sense test. You suggest that Bicyclists and pedestrians are at greater risk by "some measures." That may be true. "Some measures" indeed. |
Unreal. So obviously and patently dishonest to use "vehicle miles (or
KM)." The AOPA could use someone with your statistical abilities. |
More on "some measures."
From the AOPA's 2004 Nall report: 1 out of 413 pilots involved in an accident in 2003. 1 out of 2009 active pilots involved in a fatal accident. Now, try to follow along here Jim. If 1 out of 2009 active drivers in the USA were involved in a fatal accident, the carnage from car accidents would be in the MILLIONS. Still not convinced because of "some measures" that suggest GA flying is safer than walking, here's an excerpt from your very own Phillip Greenspun. "How dangerous is flying? There are 16 fatal accidents per million hours of general aviation. It is fairly safe to assume that when a plane crashes and someone dies, everyone on board dies. By contrast, the death rate for automobile driving is roughly 1.7 deaths per 100 million vehicle-miles. Car crashes don't always kill everyone in the car so let's use this statistic as provided, which is for an individual traveling in a car rather than for the entire car. So considering that the average airplane accomplishes a groundspeed of at least 100 miles per hour, those million hours of flight push the occupants of the plane over more than 100 million miles of terrain. Comparing 16 fatal accidents to the 1.7 rate for driving, we find that flying is no more than 10 times as dangerous per mile of travel. And since most accidents happen on takeoff or landing, a modern fast light airplane traveling a longish distance might be comparable in safety to a car. We can also look at safety per hour. This makes sense for recreational pilots who have the alternative of spending a few hours flying around or spending those hours taking a scenic drive. If the average speed of car travel is 50 miles per hour, those 1.7 deaths occur in 2 million hours of driving. This makes general aviation, with 16 deaths per 1 million hours, roughly 20 times as dangerous per hour than driving." Unfortunately, he didn't compare GA flying to walking around. |
Hey. By using vehicle miles as the standardization factor for statistical
comparisons, the Space Shuttle should be by far the safest form of transportation. Right Jim? |
"Skylune" wrote in message
lkaboutaviation.com... Now, try to follow along here Jim. If 1 out of 2009 active drivers in the USA were involved in a fatal accident, the carnage from car accidents would be in the MILLIONS. No, you're exaggerating by an order of magnitude. Do the arithmetic. --Gary |
When motorcyclists and private pilots (and bicycle riders too) decide to
conjugate pleasure with necessity, and use their vehicle to get where they're going, they impose "get there" pressures that increase risk. They ride or fly in conditions that would normally have kept them grounded. Which is why business flying (not the kind with a professional crew, but the kind where someone flies himself to a meeting or some such) is so much more dangerous than private, recreational flying. There's only one problem with this statement - the statistics (google Nall Report) show exactly the opposite is true. Michael |
OK. I concede that one. It wouldn't be in the millions. But I would
venture, without looking into it, that far less than 1 of 2009 drivers is involved in a fatal accident each year. |
| Thread Tools | |
| Display Modes | |
