LS 6 b instrument panel
Old November 18th 05, 10:54 PM posted to rec.aviation.soaring
Default LS 6 b instrument panel
OK. A LS6 is a "poor" glider compared to the Nimbus but you could find
some interesting ideas about how to do etc...
Ouch.
Having both, I'd say neither were "poor" gliders. The N3 does require
longer arms than the 6.
The LS-6 lower part of the panel should not be moved aft, or it will
bind on the stick when opening and closing the canopy. The upper
section (above knee-height) couild possibly be moved up to 2" / 50mm
aft before you'd whack your knuckles on it. Unless you (typically) have
instruments with knobs on them. In this case you'd be knuckling the
instruments well before 2".
A simpler mod might be to rework the seat back! Try padding the
headrest and moving the seat back forward a hole or two, and adjust the
tilt. If this works, cut the seat back just below the headrest and bond
it back together to achieve the angle you got with padding.
This also works for taller pilots, as it allows the seat to tilt
further back without the headrest hitting the top of the lift tube
bulkhead.
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 03:41 AM
Instrument panel labelling options John Galban Home Built 12 November 18th 04 11:42 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 06:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
