Hi BJ;
Hope all has been well with you and yours. I just sort of caught this whole thing on the fly, as we were going out the door as it was happening :-) Are you referring to the gear bounce pass or the final belly in John? I did catch a short replay later on that evening. On the final landing it looked like he went to idle cut off on both fans going into the flare but from the view angle it was hard to tell. I'm assuming he caught at least two blades out of the four on each side as he settled in but the camera angle was quartering rear which hid everything under the plane after the slide. On the bounce pass, I was just assuming he had both fans up. Did he have the left engine zeroed? Wasn't the port side the side with the gear down? Why would he zero the port engine? It looked like the bounce pass was done above the blue line anyway, but I sure wouldn't have tried that pass with the left engine down......of course it wasn't my call, but to me that would seem strange?????? Dudley "Big John" wrote in message ... Dudley Did you notice he had at least the port engine shut down. Couldn't tell from camera angle but may not have gotten the prop(s). In ny event, Good job. Big John `````````````````````````````````````````````````` ````````````````````` On Thu, 17 Nov 2005 23:05:08 GMT, "Dudley Henriques" wrote: "Chris W" wrote in message news:m95ff.11794$ih5.10682@dukeread11... Joe Feise wrote: Yeah, must be a slow news day when CNN covers a gear problem and belly landing of a King Air live... It wasn't just CNN, FOX and MSNBC were also covering it. Sure was a smooth landing. Seemed to hang a bit though, I guess ground effect is pretty huge when the wing is only a foot off the ground. -- Chris W KE5GIX He was carrying extra speed to fly it onto the runway, which he did perfectly. The REAL smooth job of flying with this incident wasn't really the landing, but rather the earlier touch and go on the left main. He had to hold up the right wing as he tried to get a little bounce on the left main trying to jar the right side retaining latches loose. That's a mean trick, and takes a good stick to pull it off without dropping the wing down far enough to catch the prop tips. It didn't work, but he got through the try without dinging it. He did a good job all around I would say. Dudley Henriques |
| Thread Tools | |
| Display Modes | |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 10:14 PM |
| World War II-era B-17 makes belly landing THE ASSOCIATED PRESS | Otis Willie | Military Aviation | 0 | May 7th 04 04:02 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
