Logging approaches
Old February 9th 04, 12:59 PM
Ron Rosenfeld
On Mon, 09 Feb 2004 12:20:44 GMT, Judah wrote:
For currency purposes, an instrument approach under Section
61.57(e)(1)(i) may be flown in either actual or simulated IFR
conditions. Further, unless the instrument approach procedure must
be abandoned for safety reasons, we believe the pilot must follow
the instrument approach procedure to minimum descent altitude or
decision height.
The poster in that thread interprets that to mean that the entire
approach down to minimums must be in IFR conditions. I'm not 100% sure I
agree that it must be interpreted this way. But what is interesting is
that the Assistant Chief Counsel who authored this document referred
specifically to "actual or simulated IFR conditions" not "actual or
simulated IMC conditions"...
There is frequently inconsistency in FAA documents. When these are
important or questioned, they get ironed out in subsequent revisions.
However, with regard to this particular opinion, there was quite a bit of
discussion at the time it was issued. I don't have the documentation to
prove the point, but I'm pretty certain that it is not considered binding
by anyone. Most consider this to be a gray area.
I generally log the approach if enough of it was conducted in instrument
conditions that I felt I really got some benefit to my currency by
conducting it. So a thin overcast at the FAF would not count for me. But
a ceiling 100-200' above DA would count.
Don't forget that the purpose of logging is for currency, and/or
qualification for a rating. If you cheat on currency, you are cheating
yourself and your passengers. And if you are going to be tested for a
rating, the examiner WILL have you conduct the approach (perhaps in
simulated conditions) down to the MDA or DA(H).
Old March 2nd 04, 05:54 PM
Ray Andraka
I find it is worth it just to go out with an instructor every six months and
do an IPC. That way you can nip any bad habits you might be developing before
they become ingrained, you get a no-questions-asked log book entry saying you
are current, and it may help with your insurance. You can usually get your
wings signoffs in the same flights, which also helps for insurance purposes.
If you are worried about your performance in front of the instructor, you need
the IPC anyway.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
What approaches are in a database? Ross Instrument Flight Rules 11 January 4th 04 07:57 PM
GPS approaches with Center Dan Luke Instrument Flight Rules 104 October 22nd 03 09:42 PM
Logging instrument approaches Slav Inger Instrument Flight Rules 33 July 27th 03 11:00 PM
Suppose We Really Do Have Only GPS Approaches Richard Kaplan Instrument Flight Rules 10 July 20th 03 05:10 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
