WAS: Red Oxide .NOW: Red colored ZC?
Old November 26th 05, 02:39 PM posted to rec.aviation.homebuilt
Default WAS: Red Oxide .NOW: Red colored ZC?
Does Zinc Chromate come in a redish/brown color so that it could be
confused with Red Oxide Primer?
Reason I'm asking is I got the CD for the Tcraft I'm examining. It has
a 337 from 1966 stating "all tubing cleaned and primed with red oxide
primer".
Then I have a more recent 337 dated 1978 which says "Tubing zinc
chromated and preserved linseed oil". That appears to be the last 337.
Since I assume ZC is green, I'm confused by what I'm seeing - Mike
Old November 26th 05, 07:53 PM posted to rec.aviation.homebuilt
primer".
I have never seen red ZC. Normal ZC is a yellowish-green; the green
stuff has a bit of black added to make it olive-colored.
Remve "_" from email to reply to me personally.
Old November 26th 05, 07:58 PM posted to rec.aviation.homebuilt
Default Red Oxide .NOW: Red colored ZC?
Michael,
From my experiences the ZC we always used was green or yellow. There is
a Zinc Oxide Primer that is also green or yellow. The ZO primers are
supposed to be alot "safer" to use. It's pretty new and I have not used it
so I can't comment on how well it works. You may need another 337 to let you
use the ZO primer, isn't all that paperwork fun?! ; )
Patrick
student SP
aircraft structural mech
"Michael Horowitz" wrote in message
primer".
Old November 27th 05, 10:00 AM posted to rec.aviation.homebuilt
On Sat, 26 Nov 2005 18:53:52 GMT, Orval Fairbairn
primer".
in the non aviation engineering world (think bridges and structural
steel) there is a wonderful alkyd enamel paint called "red oxide zinc
chromate paint" which is usually brushed or sprayed on.
it is used to corrosion proof stuff like steel truss work.
in australia we have no real problems buying this stuff in good
hardware and paint shops. it is a rust brown coloured paint.
I've found the stuff to be a wonderful corrosion proofer but have
never used it in aviation work.
( I use tempo brand rattle can zinc chromate just like you)
Stealth Pilot
Old November 27th 05, 02:57 PM posted to rec.aviation.homebuilt
Wonder if that's what was once know as "red-lead"? - MIke
On Sun, 27 Nov 2005 17:00:22 +0800, Stealth Pilot
primer".
Stealth Pilot
Old November 27th 05, 04:16 PM posted to rec.aviation.homebuilt
Yup. That - and the stuff made by Heinz that won't exit the bottle.
Rich S.
Old November 27th 05, 05:31 PM posted to rec.aviation.homebuilt
Someone answered "yes"
And then "Michael Horowitz" demonstrated the
problem with top posting in message:
To which
Rich S. responded:
Perhaps in some circles but generall 'red lead' primer used lead oxide
(not monoxide) as a pigment.
FF
Old November 27th 05, 06:26 PM posted to rec.aviation.homebuilt
Red Lead and Red Iron Oxide primers are NOT identical.
And if you ever served in the USN, the viscous material sourced in
Pennsylvania used to keep your "slider" (hamburger patty) stuck to the
bun was also called "Red Lead".
Old November 27th 05, 09:16 PM posted to rec.aviation.homebuilt
"flybynightkarmarepair" wrote in message
I guess I'm just familiar with the stuff they rolled on freighter bottoms.
Rich "Todd Shipyards, pipe shop, circa 1958" S.
Old November 29th 05, 10:41 AM posted to rec.aviation.homebuilt
On Sun, 27 Nov 2005 08:57:26 -0500, Michael Horowitz
in australia, NO.
red lead is actually a lead based paint, now banned.
red oxide zinc chromate was entirely different.
Stealth Pilot
"red oxide primer is a plus" mhorowit Home Built 6 November 27th 05 06:23 PM
Nitrous Oxide for towing safety? Jason Payne Soaring 8 March 10th 04 11:16 AM
colored airways? Chris Hoffmann Piloting 13 November 25th 03 01:08 PM
