Camera mount for Diamond DA-40?
Old November 29th 05, 07:07 AM posted to rec.aviation.piloting
Default Camera mount for Diamond DA-40?
I remember reading somewhere that there was a camera mount mod that
went under the nose of the Diamond DA-40, but I can't find it anywhere
-- not even Google. Anyone know what I am talking about?
Old November 29th 05, 10:38 AM posted to rec.aviation.piloting
On a single-engine plane, I suspect that the prop would interfere too much
with such a camera, if one goes to the length of mounting it outside.
On the other hand, a twin could work much better, and Diamond have done
some work in this area already:
http://www.diamond-air.at/download/da42mpp.pdf
Greetings,
Markus
Old November 29th 05, 11:32 AM posted to rec.aviation.piloting
What kind of camera? I wouldn't stick a camera right in the prop blast,
but a small plastic bracket and some double-sided sticky pads work
really well for mounting small video cameras (they use them on racing
motorcycles which is a very harsh environment for any camera mounting,
and they stay stuck on just fine. The fairings of the racing sidecars
are made from the same stuff as a DA-40). I've also found duct tape
works well for small video cameras.
Dylan Smith, Port St Mary, Isle of Man
Flying: http://www.dylansmith.net
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Frontier Elite Universe: http://www.alioth.net
Old November 29th 05, 12:23 PM posted to rec.aviation.piloting
Talk to the local FAA (or your local equivalent about
mounting a camera before you fly with anything just attached
with tape. Anything that falls off the airplane could be a
hazard to people on the ground and you must take
precautions. How will you control the camera?
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
"Dylan Smith" wrote in message
mount mod that
find it anywhere
the prop blast,
pads work
them on racing
camera mounting,
racing sidecars
duct tape
Old November 29th 05, 03:38 PM posted to rec.aviation.piloting
With video, you don't. You set the recorder going before takeoff and
hope you have enough tape in the recorder to last the duration.
Of course you should talk to your local aviation authorities before
doing it. Perish the thought of just going out and doing it! However, if
it stays on a motorcycle sidecar outfit during a 55 minute road race, it
will stay on a light plane.
If it's a still camera, then there's an issue of control. The
agricultural way we did it once was to make a camera box which contained
not only the camera, but a servo and receiver for a radio controlled
plane. The aircraft's occupants could press a button on the transmitter,
and the servo would press the button on the camera.
Old November 29th 05, 10:28 PM posted to rec.aviation.piloting
There are several from which too choose, you simply need to utilize
the right search engine, I through this "camera mount for diamond
da-40" into Excite.
Bush
On 28 Nov 2005 22:07:08 -0800, "cjcampbell"
Old December 1st 05, 04:24 AM posted to rec.aviation.piloting
Well, that was not what I was thinking of, but I liked it anyway!
Old December 1st 05, 05:03 AM posted to rec.aviation.piloting
Wow! did you read the MPP Mission Capabilities? it can loiter for
18hrs w/o refueling. I think I gotta pee, make that number two...
Softcomm panel mount intercom? Junk? [email protected] Owning 10 November 26th 05 07:46 AM
Panel mount for handheld Garmin GPSMap X96 series Brock Boss Owning 2 September 25th 05 02:26 AM
C206H w/Leica camera mount STC for sale Juan Jimenez General Aviation 9 February 1st 05 05:59 AM
C206H w/Leica camera mount STC for sale Juan Jimenez Owning 9 February 1st 05 05:59 AM
A-4 gun camera question Guy Alcala Naval Aviation 0 April 10th 04 07:33 AM
