GPS and old-fashioned thinking?
Old December 7th 05, 05:29 PM posted to rec.aviation.ifr
Default GPS and old-fashioned thinking? - ADS-B position broadcasting
"Stan Gosnell" wrote:
It's relatively cheap, and looks like a great system.
Uh-oh. Sounds like a couple dozen more OTS NOTAMs to read for every
trip.
  #82
Old December 7th 05, 05:31 PM posted to rec.aviation.ifr
"john smith" wrote in message
Not all approaches provide a decent transition
Do you mean a "decent" or "descent" transition?
What would you consider an "indecent" transition?
Asking "How about it?" without buying dinner first.
Dan
"The future has actually been here for a while, it's just not readily
available to everyone."
- some guy at MIT
  #83
Old December 7th 05, 11:03 PM posted to rec.aviation.ifr
can be installed at any tower, wire crossing, or other obstacle, and
receives transponder transmissions, determines if an aircraft is likely to
hit the obstacle, and transmits a warning on all VHF frequencies.
That sounds like a stupid system. Just what we want! (add sarcasm) A bunch
of warnings that go off on all our comm's so often that we are both annoyed
by them and desensitized by them.
Buy a GPS with terrain and obstacle warning. Then someone's buzzing, low
approach, landing, corridor flying or stupidity won't annoy everyone in a
ten mile radius.
Kobra
  #84
Old December 8th 05, 11:36 AM posted to rec.aviation.ifr
Stan Gosnell wrote:
Scott Moore wrote in news:dn293r$i4k$2
@news1nwk.SFbay.Sun.COM:
Hell, someday they are going to put ADS-B transmitters ontop of
radio towers. It will happen.
There is already a system in existence that does a good job, and the FAA
has, or maybe still is, evaluated it. It was designed in Sweden, IIRC, and
hit the obstacle, and transmits a warning on all VHF frequencies. All that
is required in the aircraft is a transponder and a VHF radio turned on. It
operates on solar cells and batteries, as well as AC if available. It's
ADS-B is going to be the ATC separation system. The movement is
probably irreversible. Austrialia (spelling?) is already a big player.
Avoidance of passive obstacle in airspace not suitable for IFR
navigation will become more and more a cockpit responsibility as
technology advances. My Garmin 296 already does an awesome job, at
least in the U.S., where all the NACO-recorded obstacles are in the
database.
  #85
Old December 8th 05, 11:41 AM posted to rec.aviation.ifr
Andrew Gideon wrote:
G Farris wrote:
The missed approach is part of the procedure, and if you've done
good you have it all dialled-in, briefed and ready to fly.
LOC22 at KCDW requires the localizer for the missed. The NDB-A (which has a
GPS overlay now) also uses the same NDB in the missed approach procedure.
Not all approaches provide a decent transition to a missed approach in the
case of a failure of the primary NAVAID. I find that astonishing.
- Andrew
There is so much protected airspace for these procedures that a primary
nav failure will not probably create a safety issue. And, if the
aircraft has a GPS moving map that provides a redundant positive course
guidance alternative/backup.
In the case of the new RNAV (RNP) SAAAR procedures, GPS is presumed to
fail during the approach. If the missed approach can be serviced with a
Level 1 TERPs missed approach area (criteria that have been used for
RNAV (GPS) missed approach design for about three years now, the pilot
is presumed to be able to do short term dead recogning for extraction in
the event of loss of GPS. If, howver, the missed approach requires
smaller RNP values than provided by a Level 1 missed approach, then the
aircraft must have IRU positioning to fall back on with loss of GPS.
  #87
Old December 9th 05, 07:06 AM posted to rec.aviation.ifr
"Stan Gosnell" wrote in message
and
that
Think about what will have to the airwaves when such a broadcast is made.
Better to have detection of the signal active an alarm in the subject
aircraft rather than broadcasting it to EVERYONE in the area.
  #88
Old December 9th 05, 07:08 AM posted to rec.aviation.ifr
The radio is very low-power, and thus short-range.
Imagine what even a low power transmitter would do it operating on a tower
right near an airport.
I don't have such a
GPS, and my company isn't likely to buy a few hundred of them in my
lifetime.
That's a non-reason for such a system.
  #89
Old December 9th 05, 09:31 PM posted to rec.aviation.ifr
Matt Barrow wrote On 12/08/05 22:06,:
and
that
Kinda like ADS-B. Hey, didn't we start there ?
  #90
Old December 9th 05, 11:32 PM posted to rec.aviation.ifr
"Scott Moore" wrote in message
and
to
that
Not on voice channels that EVERYONE heard the warning (and then had to
decide if THEY were the one being warned.
