required vertical altitude separation
Old February 28th 04, 01:20 PM
Default required vertical altitude separation
Is 1000 feet the absolute minimum vertical separation between ifr
aircraft? Or can atc assign 3500 feet to one, and 4000 to another,
and have no lateral separation??
Secondly, any different for a situation where one is ifr at 4000 ft,
and a vfr aircraft is being vectored at 3500 feet, with no lateral
separation?
Any exceptions?
Stan
Old February 28th 04, 02:25 PM
Brad Z
1,000 for IFR-IFR. 500 for IFR-VFR. This can be reduced provided there is
visual contact and the visual separation is maintained by the pilot.
From Faa Order 7110.65 (ATC)
Section 5. Altitude Assignment and Verification
4-5-1. VERTICAL SEPARATION MINIMA
Separate instrument flight rules (IFR) aircraft using the following minima
between altitudes:
a. Up to and including FL 290- 1,000 feet.
7-7-3. SEPARATION
Separate VFR aircraft from VFR/IFR aircraft by any one of the following:
a. Visual separation, as specified in para 7-2-1, Visual Separation, para
7-4-2, Vectors for Visual Approach, and para 7-6-7, Sequencing.
NOTE-
Issue wake turbulence cautionary advisories in accordance with para 2-1-20,
Wake Turbulence Cautionary Advisories.
b. 500 feet vertical separation.
c. Target resolution when using broadband radar systems. The application of
target resolutions at locations not using broadband radar will be
individually approved by the Program Director for Air Traffic Planning and
Procedures, ATP-1.
separation?
Any exceptions?
Stan
Old March 1st 04, 01:41 AM
Thanks for the replies Brad and Newps
With as little as 500 ft between 2 aircraft, ifr/vfr, does the
controller have to take into account the ifr aircraft may have tcas?
Doesn't 500 ft separation generate an RA, in which case a tcas climb
could now infringe any 1000 ft separation from a third, and ifr,
aircraft?
Stan
On Sat, 28 Feb 2004 13:25:06 GMT, "Brad Z"
Calculating vertical time and distance in a stall turn (US Hammerhead) Dave Aerobatics 3 November 20th 03 11:48 AM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 01:39 AM
Why is ADF required on ILS approach? Rich Raine Instrument Flight Rules 27 August 1st 03 06:14 PM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 04:29 PM
