Turbine Duke or turbine Baron?
Old December 9th 05, 11:14 PM posted to rec.aviation.piloting
Default Turbine Duke or turbine Baron?
I got an email response from the guys at Rocket Engineering about their
PT6A conversion of a P-Baron. He mentioned they're finishing STC work
for their turbine Duke conversion and I wondered which airplane might
make the better platform for conversion. Their preliminary numbers for
the -21 engined P-Baron are : Max climb rate 5000ft/min, useful load
2050, time to climb to 25,000 7min., high speed cruise of 300+ kts at
FL250 @ 64gph, long range cruise 250+ kts at FL250 @ 46gph which sounds
pretty impressive (to me, anyway) but I wonder if the Duke would be any
faster with the same power? I've read here previously that the Duke is
pretty draggy as airframes go and should/could be faster with its 380hp
Lycs. With a stated cost of $767k for the Duke with new -21 engines it
sounds like that a pretty cheap way to go fast (everything's relative,
right?)
Wooly
Old December 10th 05, 12:48 AM posted to rec.aviation.piloting
The Duke would be the way I'd go. The Duke was designed for
high altitudes and has a better panel, and cabin. The Baron
will be unstable at 300 TAS and twitchy...
For the same money, as the conversion, you could probably
buy a B or C90 King Air and have a real cabin class, but the
Duke is a nice flying airframe and it is very strong and
heavily built.
I would be most interested in prop/ground clearance issuers,
are they using 4 bladed props?
James H. Macklin
ATP,CFI,A&P
about their
finishing STC work
airplane might
numbers for
useful load
300+ kts at
which sounds
would be any
the Duke is
with its 380hp
new -21 engines it
| right?)
| Wooly
Old December 10th 05, 06:55 PM posted to rec.aviation.piloting
The spec sheet he included said 4 blade Hartzells.
Interesting point about the Baron's behavior at 300kts - at approx
50-60kts faster than the piston engined plane's cruise speed I'm
guessing trim might be a bit more critical. That alone might make the
plane twitchy, as it was never designed to go that fast.
A quick check on ASO found a bunch of C90 and E90s for the same dough,
although they wouldn't have new engines as the converted Barons and
Dukes.
Old December 10th 05, 07:36 PM posted to rec.aviation.piloting
High altitude. thinner air, stability become more critical.
Higher speeds can actually get into Mach problems. The Duke
is certified to 30,000 feet and the P58 Baron to only
25,000.
James H. Macklin
ATP,CFI,A&P
at approx
speed I'm
might make the
same dough,
Barons and
| Dukes.
Old December 10th 05, 09:04 PM posted to rec.aviation.piloting
I guess that would explain why the speeds are quoted at FL250 for the
Baron. I assume then the ASI must be replaced with a unit with a Vmo
indicator? If the Duke is cert up to 30k does that mean its cabin diff
is higher than the P-Baron?
Old December 10th 05, 09:20 PM posted to rec.aviation.piloting
I seem to remember they are all at about 5 PSI.
FL250 for the
with a Vmo
its cabin diff
Old December 11th 05, 06:11 PM posted to rec.aviation.piloting
right?)
Wooly
For the same money, you could buy a Mitsubishi Solitaire and go faster with
a larger cabin and (probably) more reliable systems. I did see the turbine
Duke when it landed in Sandpoint and it looks great.
Mike
MU-2
Old December 11th 05, 08:34 PM posted to rec.aviation.piloting
"Mike Rapoport" wrote in message news:m5Zmf.2241
I did see the turbine Duke when it landed in Sandpoint and it looks great.
Which Sandpoint? Alaska?
Old December 11th 05, 08:49 PM posted to rec.aviation.piloting
There's a Sandpoint in Alaska?
Old December 12th 05, 05:05 AM posted to rec.aviation.piloting
Idaho.
"John Gaquin" wrote in message
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 08:50 PM
Rick Stitt, Joe Rinke, Rinke Aerospace, BJ Schram, Mini 500, Turbine, Helicopter, Kit TurbineMini Richard Rotorcraft 2 January 24th 04 02:15 AM
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit TurbineMini Richard Rotorcraft 0 January 16th 04 12:48 AM
TRUTH OF THE MINI-500 TURBINE CONVERSION Dennis Chitwood Rotorcraft 10 January 7th 04 06:33 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 10:41 AM
