Kestrel Maintenance Manual
Old December 11th 05, 08:34 PM posted to rec.aviation.soaring
Default Kestrel Maintenance Manual
Hi,
Has anyone got a maintenance manual for a Kestrel 19 that I could
borrow/scan or whatever.
Cheers
Robin
Robin Birch
Old December 11th 05, 09:27 PM posted to rec.aviation.soaring
To the best of my knowledge there is no maintenance manual available -
at least for the Glasfluegel Kestrel H401. For maintenance purposes
there is the check list for the annual inspection and the 3000 hours
inspection check list. Both I have in German only.
regards
Christoph Lhota
Kestrel 17m, Scharnstein, Austria
Old December 11th 05, 10:04 PM posted to rec.aviation.soaring
In message . com,
Christoph writes
I've got a Slingsby 19m one but I think that the bits I am interested in
are the same. The actual drive (after the gearbox) to the Aileron and
the hinges for the ailerons and flaps. Anything you've got on this area
would be great, German or English.
Cheers
Robin
regards
Christoph Lhota
Robin Birch
Old December 12th 05, 03:42 PM posted to rec.aviation.soaring
Perhaps you can contact Streifeneder, who currently is responsible for
the continuaing airworthiness of the type:
http://www.streifly.de/home-eng.html
Old December 12th 05, 04:52 PM posted to rec.aviation.soaring
In message .com,
stephanevdv writes
Thanks for this. I will.
Robin
Robin Birch
Old December 12th 05, 08:57 PM posted to rec.aviation.soaring
I dont think there was one issued for the K17.
I have a K17 version available in PDF on http://www.classicglider.info
Regards
Al
Old December 13th 05, 11:35 PM posted to rec.aviation.soaring
In message . com,
" writes
Regards
Al
Down loaded. Many thanks for pointing it out.
Regards
Robin
PS: Got on to Striefender and have a quote for overhauling the Aileron
drives :-)
Cheers
Robin
Robin Birch
Old April 24th 19, 12:28 AM posted to rec.aviation.soaring
Maintenance data is in the "Pilot notes"...
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
ASW-20 Maintenance manual wanted Jeff Dorwart Soaring 0 June 12th 04 01:18 AM
