GPS 396 audio terrain warnings
Old December 8th 05, 04:07 AM posted to rec.aviation.owning
Default GPS 396 audio terrain warnings
Dave Butler wrote:
Does anyone else have their Garmin 396 connected to the audio in their airplane?
If so, do you get terrain warnings every time you approach an airport to land?
I do, but Garmin doesn't seem to be very interested in helping. I've exchanged
several emails with their tech support. They don't acknowledge that there is
anything wrong.
They say they have "some algorithms" to prevent the audio terrain alert when
approaching an airport to land. They say they might not work correctly for all
airports. My experience is that they don't work for any airport I have visited.
If anyone else is seeing this behavior, please contact Garmin so that they will
know I'm not the only one.
Thanks.
Old December 8th 05, 04:10 AM posted to rec.aviation.owning
anything wrong.
Thanks.
Old December 8th 05, 05:40 AM posted to rec.aviation.owning
The prob I've had with the audio is a loud buzz unless I unplug the
power and run on battery.
Folks on Cessna Plots forum have had good luck with this:
http://www.crutchfield.com/S-xGL4Bin...35&i=127SNI135
and also a similar device available from RatShack
Old December 8th 05, 05:44 AM posted to rec.aviation.owning
Google groups munched the url. Try:
http://tinyurl.com/8dn9o
Old December 8th 05, 03:57 PM posted to rec.aviation.owning
Radio Shacks is cheaper but requires adapters:
http://www.radioshack.com/product/in...entPage=family
Ground Loop Isolator $16.99 Model: 270-054
You'll need 2 (depends what you're adapting to) - RCA Female to Mini
Stereo Male adapters Catalog #: 274-883 $5.99 ea.
Cheaper here ($2.38 each):
http://www.valcoelectronics.com/Merc..._Code =18-008
ES-034 The ES-034 isolates multiple components to prevent ground loops.
It may be used as a trouble-shooting installation tool, to break grounds
without removing grounding parts. The ES-034 is designed to interface
with line-level outputs and is equipped with two male and female RCA
jacks, for interconnection with cable adapters/components. $14.00
http://www.buyreliant.com/caudio/noise.htm
http://www.valcoelectronics.com/Merc...t_Code =ES034
So you'll need one of these (Stereo mini to dual RCA male $3.58):
http://www.valcoelectronics.com/Merc...ct_Code =Y3AA
Old December 9th 05, 12:17 AM posted to rec.aviation.owning
Thanks to all. I'm going to try one of these approaches and see.
Old December 12th 05, 10:11 PM posted to rec.aviation.owning
Mike,
You are The Man! I bought one and it works perfectly!! Thanks a bunch!!!
Kobra
Old December 16th 05, 10:22 PM posted to rec.aviation.owning
airplane?
land?
replying to myself
From Garmin's web site today:
Changes made from version 2.70 to 2.80:
* Improved behavior of audible terrain alerts when operating near airports.
Thanks, Garmin!
Old December 17th 05, 03:21 AM posted to rec.aviation.owning
Dave Butler wrote:
airplane?
land?
replying to myself
Thanks, Garmin!
Cockpit Audio wiring (hyjacked from "gear warning") Bill Daniels Soaring 17 November 20th 05 05:02 PM
Audio Panel Suggestions Jay Honeck Owning 5 May 9th 05 03:00 PM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 6th 04 12:14 AM
S-TEC 60-2 audio warning Julian Scarfe Owning 7 March 1st 04 09:11 PM
Gleim Instrument Pilot Audio CD Set AND Gleim Instrument Pilot FAA Test Prep Software - together on Ebay Cecil E. Chapman Products 0 January 15th 04 12:34 AM
