Approach speeds for ILS
Old March 2nd 04, 09:28 PM
Roger Tracy
It's certainly a matter of perception and everyone thinks about
it differently. My feeling is it's a combination of both. I start
with slight pitch changes and adjust the throttle accordingly.
If you're timing your ILS approaches you'd want to maintain
a constant speed.
"Ray Andraka" wrote in message
Hmm, I was taught to use the throttle to stay on glideslope, not the
elevator.
I find using the throttle results in more controllability.
Roy Smith wrote:
I s'pose. But you really shouldn't be playing with the throttle
constantly either. Somewhere along the line I picked up adding "DFWTP"
to my ILS checklist. DFWTP at GS intercept, GUMPS at DH. It stands for
"Don't F*** With The Power".
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
  #72
Old March 2nd 04, 10:44 PM
Ray Andraka
I used to do it with elevator, till an instructor on one of the refresher
courses I took showed me how much better power worked for my airplane (a
cherokee six). I can keep the needle centered much better with small changes in
power than I can with the elevator. SO what I mean by controllability, is the
ability to keep the needle pegged.
Peter Duniho wrote:--
--Ray Andraka, P.E.
email
  #73
Old March 2nd 04, 10:48 PM
Ray Andraka
Using the throttle will keep the speed constant. Using pitch will change the
airspeed, albiet only slightly for the small pitch changes associated with
flying an approach. Likewise, I use only throttle on a non-precision approach
because it keeps the airspeed constant (plus I know how much MP reduction is
required for a specific descent rate)
a constant speed.
elevator.
--Ray Andraka, P.E.
email
--Ray Andraka, P.E.
email
  #74
Old March 3rd 04, 12:20 AM
Matthew S. Whiting
elevator.
A little late to the thread, aren't you? That was over a month ago.
Anyway...
Your comment points to a classic debate, of course. Likely that no person
on one side will be convinced to change their methods. However, suffice to
say there are plenty of us that find that elevator is a more responsive and
useful way to adjust glideslope during an instrument approach. You're above
L/Dmax (so pitch changes do "what you expect"), and the result of a pitch
change is somewhat more uniform from airplane to airplane (power changes can
produce radically different results from airplane to airplane, depending on
drag, weight, and type of powerplant).
Yes, but you typically also want to maintain a given airspeed while on
the approach. Using small throttle adjustments allows you to track the
glide path while maintaining a uniform airspeed. Using the elevator
won't do that. I always trim to the desired approach speed and then
make small throttle adjustments to track the GS ... of course, if you
have dramatic wind shear, then you may need large throttle and elevator
inputs.
Either throttle or pitch can be used for the same purpose, with
approximately the same effect.
All that said, IMHO if you're going to say something like "I find using the
throttle results in more controllability", you ought to define what
"controllability" means. Making glideslope changes with pitch instead
certainly doesn't cause the airplane to go out of control, so it's not
really clear what difference you're talking about.
It does allow you to keep better control of the airspeed.
Matt
LSA Approach speeds Ace Pilot Home Built 0 February 3rd 04 06:38 PM
How much protection on approach? Michael Instrument Flight Rules 20 January 15th 04 06:58 PM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 06:20 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 06:22 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
