Fine example of Tarver Engineering release for service
Old March 2nd 04, 11:55 PM
Ray Andraka
Can you point to a reg tht says that? I don't think it is true. Mine was
IFR certified when I bought it, and it did not have alternate static (I've
since added it). Also the FAA materials for the IFR written mention several
times that breaking the VSI glass is the way to get alternate static on an
airplane that doesn't have a valve. I wouldn't think they'd make such a big
deal about it if an alternate static source was requried for IFR cert.
The CO wrote:
IIRC in fact, for an aircraft to be certified for IFR it has to have an
alternate
static source *as well*.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old March 3rd 04, 03:55 AM
It should be mentioned here that this trick only works on an
unpressurized a/c. You won't get much activity on the VSI needle
if you try this with a pressurized aircraft!.
-Gord.
Old March 3rd 04, 05:01 AM
The CO
"Ray Andraka" wrote in message
was
(I've
several
on an
That might work if the cabin was unpressurised, depends on whether the
guage face
was vented to the static side of the pressure balance.
Ah, in Australia mate. I can't quote the ANO/R off the top of my head
but
to be certified for Class 1 it needs an alternate static source IIRC.
I'll see if
I can find the ANO/R somewhere.
(ANO= Air Navigation Order ANR= Air Navigation Regulation)
I can't speak for the FAA, so if they don't require alternate static
source for
Class 1 IFR I'm rather surprised, but I guess it could be the case, I
don't know.
Class 4 IFR (NVMC) doesn't require it in Oz.
The CO
