Wind/Solar Electrics ???
Old December 16th 05, 06:36 PM posted to rec.aviation.owning,sci.electronics.design
Default Wind/Solar Electrics ???
Ross Richardson wrote:
Hey Jim,
Try looking through this.
http://www.homepower.com/
My son has provide me some literature on renewable energy and I am
convinced with some up front spending you can survive anywere without
the power grid. You may need a 5KW generator at time when the wind,
solar, etc give out.
Regards, Ross
C-172F 180HP
KSWI
RST Engineering wrote:
After much thought and ponderance, I've come to the conclusion that to
electrify the hangar using Pacific Gas & Electricity (PG&E -- Pigs,
Goats, and Elephants) isn't clever. By the time you get them to hang
a meter ($5k), trench from the power pole to the end of the row of
hangars, conduit romex to 35 hangars at a cost somewhere around $50k
($1500 per hangar), and then pay the monthly electric bill, you could
buy a hell of a wind/solar system and perch it on the (flat) hangar roof.
Before I flail about gathering data, has anybody on these ngs actually
installed a design whereby a hefty solar panel charges a hefty battery
to run a hefty inverter? It doesn't have to be absolutely "clean"
sinewave power as all we are running are fluorescent shop lights
(about 400 watts worth), every now and again a small compressor, a
small drill press, a small grinder, but none of these last few at the
same time.
My hit on it is that a 2 kW inverter would be more than enough to
handle the AC side of it, and a bank of 12 volt truck batteries would
work for the DC side of it, but there are the problems of parallelling
large batteries, how to combine the outputs of solar cells and wind
generators, and a reasonable source for all this stuff.
There are issues around protecting the solar cells from hail, which we
do get from time to time, battery acidic gases inside a hangar where a
very expensive lump of aluminum is sitting for months on end, sizing
the solar cell and wind generators, and other considerations along
these lines.
Comments appreciated.
http://www.tinaja.com/glib/energfun.pdf
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email:
Please visit my GURU's LAIR web site at
Old December 15th 05, 09:48 PM posted to rec.aviation.owning,sci.electronics.design
Jim,
Try alt.energy.homepower or alt.solar.photovoltaic. Lots of experts there.
Michelle
electrify the hangar using Pacific Gas & Electricity (PG&E -- Pigs, Goats,
and Elephants) isn't clever. By the time you get them to hang a meter
($5k), trench from the power pole to the end of the row of hangars, conduit
romex to 35 hangars at a cost somewhere around $50k ($1500 per hangar), and
then pay the monthly electric bill, you could buy a hell of a wind/solar
installed a design whereby a hefty solar panel charges a hefty battery to
run a hefty inverter? It doesn't have to be absolutely "clean" sinewave
power as all we are running are fluorescent shop lights (about 400 watts
worth), every now and again a small compressor, a small drill press, a small
grinder, but none of these last few at the same time.
My hit on it is that a 2 kW inverter would be more than enough to handle the
AC side of it, and a bank of 12 volt truck batteries would work for the DC
side of it, but there are the problems of parallelling large batteries, how
to combine the outputs of solar cells and wind generators, and a reasonable
There are issues around protecting the solar cells from hail, which we do
get from time to time, battery acidic gases inside a hangar where a very
expensive lump of aluminum is sitting for months on end, sizing the solar
cell and wind generators, and other considerations along these lines.
Old December 16th 05, 01:17 AM posted to rec.aviation.owning
Try an outfit called "Real Goods". They are a bunch of old hippies who
started out with a lot of alternative energy products. They are now into
consumer goods, but I believe they still do solar. Their older catalogs
have a lot of planning information in them. At one time they were
trying to sell some older used panels that a power company offed when
they shelved a project. It was many years ago, but they may still have
some left.
Running fluorescents is a snap with solar. Any bigger load gets complex
and expensive fast.
Good Luck,
Mike
Old December 16th 05, 01:20 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
yes, thats when solar pv starts to look good.
There are 2 main invertor options, sine or modified sine, which is IRL
rectangular wave. IIRC, iron fl ballasts and motors can overheat on
MSW, so all your apps ideally want sine. However MSW is much cheaper,
and there are workarounds. Fl lights can be run at just slightly
reduced power, or heatsinks added to the ballasts, etc. Electronic
ballast lights would run happily on 150v dc. Motor driven tools would
be fine as is unless youre running them to where they already get
seriously hot, ie heavy use. There are ways round it if it proves to be
an issue.
ok, first with those powers it would make more sense to run your
battery back at apx 150v (assuming you want 110v ac) and use a simple
chopper to produce the ac. Your output will then have unregulated
V_peak and regulated constant rms. That should work for all your loads.
You should add a parallel diode across each battery cell, so that one
cell going down has little effect on system performance, and enables
everything to continue running. Ditto with the panels, there its
particularly important to have a diode across every panel when youre
running them at HT.
This avoids parallelling batteries (not that thats needed anyway), plus
reduces cost of invertor and wiring. Also it means you can supply 150v
dc to mains CFL bulbs, electronic ballasted fl lights, and anything
else that rectifies the mains, again cutting down on system cost and
improving reliability. Use a different plug/socket type for the dc
supply.
One way to shave 10-20% off power consumption would be to up your
supply frequency slightly, this would work nicely with magentic ballast
lights and brushed motors, but not induction motors. FWIW brushed
motors can run on dc anyway - but not @ 150v.
Solar pv is cheaper than wind, and has less significantly issues, so
I'd stick to solar.
Battery case is vented to the outside.
sizing the solar
alt.solar.photovoltaic is the place to go.
Also dont overlook simple ways to cut cost. A minimal cost reflector
outside a window can be used to increase daylight levels, and delay
lighting dwitch on until later in the day, thus reducing system cost.
And of course a switchbank for your lighting will enable you to use the
lights only where theyre wanted at the time. No sense lighting the
whole place up bright when youre only working in one area.
And dont forget batteries dont last forever, you need to account for
future replacement. Beating your PG&E costs should not be difficult, as
long as its designed competently.
NT
Old December 16th 05, 01:55 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
On 15 Dec 2005
You might start with a small bank of golf cart batteries from Sam's
Club, and a refurbished inverter/charger from here
http://www.sunelec.com/Distributors_...cccltrace.html A Trace
SW would be best, but you'd probably be happy with a DR. Use a Honda
EU2000 for a charger to get started and as a backup later on. Add PV
as your budget allows. Excellent info on home built wind turbines here
http://www.otherpower.com/. There's no problem paralleling solar and
wind charge controllers. Include a proper system monitor like an
E-Meter or TriMetric.
Old December 17th 05, 04:12 PM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
No doubt you are correct....
But a "modified sine wave" inverter is a way for someone to tell you that
you are buying a device which doesn't put out a proper sine wave... rather
one which consists of an approximate sinusoidal curve made up from square
bits...
So it's not a modified sine wave, but rather a near sine wave with lots of
edges... Inferior in every way (but price) to a real sine wave inverter...
Al...
"George Ghio" wrote in message
an issue.
Small point.
Why would anybody modify a sine wave?
When people try to sell a "Modified Sine wave" inverter they are either
ignorant or shysters.
Old December 17th 05, 05:20 PM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
No. GG is the ignorant one again. MSW is professional EE talk.
Nick
Old December 18th 05, 03:57 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
Hi Nick
MSW is a shysters sales pitch which misrepresents the product.
Sort of like someone selling bilge pumps as suitable for continuous duty.
Nick
Question on 172 M electrics... (1974 Skyhawk II) [email protected] Piloting 8 April 10th 04 05:52 AM
