Discus polar curve at high speeds
Old December 20th 05, 02:59 AM posted to rec.aviation.soaring
Default Discus polar curve at high speeds
In article , Eric Greenwell wrote:
Gary Emerson wrote:
To go from level flight at 125 knots to 250 knots would require losing
over 2000 feet in this zero lift flight, much of which would vertical. I
have to wonder how a pilot could resist pulling back on the stick or
opening the spoilers for such a long distance! And how carefully he'd
have to fly to avoid G forces that would remove the wings; after all,
this maneuver isn't in the usual glider training syllabus.
You might also want to consider the twist in the wings.
Ever looked along your wing at high speed and noticed the tips bending down?
At really high speed you can twist your wings off. A blanik did that in
NZ a few years ago. One wing twisted off leading edge up, the other went
leading edge down.
Philip Plane _____
Glider pilots have no visible means of support
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
Control Reversal in WWII Eunometic Military Aviation 14 June 27th 04 02:03 PM
Cambridge 302 -or- Borgelt B50 plus data logger Romeo Delta Soaring 25 May 30th 04 10:50 AM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 10:47 PM
High Flight NOTAM Kirk Stant Military Aviation 1 September 10th 03 04:31 AM
