I'll echo that... we did an overhaul by a local shop. Piper Pawnee
O-540-235HP with STC to 250HP He did his normal run at the shop.. then once installed.. it was a quick (short) static run (mag check) to check oil pressures and leaks.. then shut down inspect... Then it was start and go.. no ground time.. it was 100F out and we did not want to overheat on the ground... FULL Power climb to 10,000MSL where the outside temps were cooler and we could run it full throttle at cruise. Stayed there for 1+30 monitoring oil temp and pressure (no CHT available). A few more flights at altitude to accumulate about 5 hours total before putting it to work, glider tow. Over 55 hours on the engine now and just swapped from Mineral to regular AD. All appears well. BT "dlevy" wrote in message news ![]() Same here. "Paul kgyy" wrote in message ups.com... snip I did my first 30 minutes orbiting the airport with tower permission. |
| Thread Tools | |
| Display Modes | |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Chevy LS2 and Trans??? any real issues besides weight | MrV | Home Built | 82 | November 18th 05 04:11 AM |
| P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 02:09 AM |
| more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 05:22 AM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
