Biplane design questions
Old December 30th 05, 09:47 PM posted to rec.aviation.homebuilt
Default Biplane design questions
"Chris Wells" wrote in message
A few questions, for those in the know:
Both of the radio-controlled biplanes I've owned were designed with
the lower wing at a higher AOA, so that it stalled first. They also had
the upper wing farther forward than the lower.
If the lower wing stalls, the CG will be a little on the aft side of
the upper wing. Wouldn't it be better for the upper wing to be behind,
so that the CG is a little more forward? I've seen some biplanes like
this, such as the Beech Staggerwing, but most seem to have the upper
wing in front.
While my R/C had the ailerons on the lower wing (my other one had no
ailerons), it seems most of the biplanes have them mounted on the upper
wing. It would seem to me that the lower wing would be safer, because
you'd have a harder time tip stalling that way - the upper wing would
be able to keep flying after you tip-stalled the lower one. Why is it
the other way around on most biplanes?
Also, it would seem only necessary to put washout in the upper wing,
keeping the lower wing flat. Is this the case with most biplanes, or do
they put washout in both the wings?
Chris Wells
Interesting points, but I think you've got the washout thing backwards. If
the lower wing is designed first, don't you want wash-out in it to keep the
tip from stalling first and causing a wing to drop?
KB
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
